RTEMS 6.1
console-termios.h
2
3/*
4 * Copyright (c) 2014 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef BSP_CONSOLE_TERMIOS_H
29#define BSP_CONSOLE_TERMIOS_H
30
31#include <rtems/termiostypes.h>
32
33#ifdef __cplusplus
34extern "C" {
35#endif /* __cplusplus */
36
68
72typedef struct {
79 const char *device_file;
80
85
90
95
101
106
116
122extern const size_t console_device_count;
123
126#ifdef __cplusplus
127}
128#endif /* __cplusplus */
129
130#endif /* BSP_CONSOLE_TERMIOS_H */
const char * device_file
The device file path.
Definition: console-termios.h:79
bool(* console_device_probe)(rtems_termios_device_context *context)
Console device probe function type.
Definition: console-termios.h:67
bool console_device_probe_default(rtems_termios_device_context *context)
Returns true and does nothing else.
Definition: console-termios-init.c:35
const rtems_termios_device_handler * handler
The Termios device handler.
Definition: console-termios.h:89
rtems_termios_device_context * context
The Termios device context.
Definition: console-termios.h:99
const console_device console_device_table[]
Table for console devices installed via console_initialize() during system initialization.
Definition: console.c:52
console_device_probe probe
The device probe function.
Definition: console-termios.h:84
const rtems_termios_device_flow * flow
The Termios device flow control handler.
Definition: console-termios.h:94
Count of entries in the console_device_table.
Definition: console.c:61
Definition: console-config.c:62
Console device information.
Definition: console-termios.h:72
Definition: termiosdevice.h:68
Definition: termiosdevice.h:207
Definition: termiosdevice.h:100
