RTEMS 6.1
percpu.h
2
20/*
21 * Copyright (C) 2018, 2020 embedded brains GmbH & Co. KG
22 *
23 * Redistribution and use in source and binary forms, with or without
24 * modification, are permitted provided that the following conditions
25 * are met:
26 * 1. Redistributions of source code must retain the above copyright
27 * notice, this list of conditions and the following disclaimer.
28 * 2. Redistributions in binary form must reproduce the above copyright
29 * notice, this list of conditions and the following disclaimer in the
30 * documentation and/or other materials provided with the distribution.
31 *
32 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
33 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
34 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
35 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
36 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
37 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
38 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
39 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
40 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
41 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
42 * POSSIBILITY OF SUCH DAMAGE.
43 */
44
45#ifndef _RTEMS_CONFDEFS_PERCPU_H
46#define _RTEMS_CONFDEFS_PERCPU_H
47
48#ifndef __CONFIGURATION_TEMPLATE_h
49#error "Do not include this file directly, use <rtems/confdefs.h> instead"
50#endif
51
52#ifdef CONFIGURE_INIT
53
54#include <rtems/confdefs/bsp.h>
55#include <rtems/score/context.h>
56#include <rtems/score/percpu.h>
57#include <rtems/score/smp.h>
58
59#ifdef __cplusplus
60extern "C" {
61#endif
62
63/* Ensure that _CONFIGURE_MAXIMUM_PROCESSORS > 1 only in SMP configurations */
64#if defined(CONFIGURE_MAXIMUM_PROCESSORS) && defined(RTEMS_SMP)
65 #define _CONFIGURE_MAXIMUM_PROCESSORS CONFIGURE_MAXIMUM_PROCESSORS
66#else
67 #define _CONFIGURE_MAXIMUM_PROCESSORS 1
68#endif
69
70#ifdef RTEMS_SMP
72 _CONFIGURE_MAXIMUM_PROCESSORS;
73
75 _Per_CPU_Information[ _CONFIGURE_MAXIMUM_PROCESSORS ];
76#endif
77
78/* Interrupt stack configuration */
79
80#ifndef CONFIGURE_INTERRUPT_STACK_SIZE
81 #if !defined(CONFIGURE_DISABLE_BSP_SETTINGS) && \
82 defined(BSP_INTERRUPT_STACK_SIZE)
83 #define CONFIGURE_INTERRUPT_STACK_SIZE BSP_INTERRUPT_STACK_SIZE
84 #else
85 #define CONFIGURE_INTERRUPT_STACK_SIZE CPU_STACK_MINIMUM_SIZE
86 #endif
87#endif
88
89#if CONFIGURE_INTERRUPT_STACK_SIZE % CPU_INTERRUPT_STACK_ALIGNMENT != 0
90 #error "CONFIGURE_INTERRUPT_STACK_SIZE fails to meet the CPU port interrupt stack alignment"
91#endif
92
94 _ISR_Stack_size,
96);
97
98#define _CONFIGURE_INTERRUPT_STACK_AREA_SIZE \
99 ( CONFIGURE_INTERRUPT_STACK_SIZE * _CONFIGURE_MAXIMUM_PROCESSORS )
100
101char _ISR_Stack_area_begin[ _CONFIGURE_INTERRUPT_STACK_AREA_SIZE ]
102RTEMS_ALIGNED( CPU_INTERRUPT_STACK_ALIGNMENT )
103RTEMS_SECTION( ".rtemsstack.interrupt" );
104
108 + _CONFIGURE_INTERRUPT_STACK_AREA_SIZE
109);
110
111/* Thread stack size configuration */
112
113#ifndef CONFIGURE_MINIMUM_TASK_STACK_SIZE
114 #define CONFIGURE_MINIMUM_TASK_STACK_SIZE CPU_STACK_MINIMUM_SIZE
115#endif
116
117#ifndef CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
118 #define CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE \
119 ( 2 * CONFIGURE_MINIMUM_TASK_STACK_SIZE )
120#endif
121
122/* Idle thread configuration */
123
124#ifndef CONFIGURE_IDLE_TASK_STACK_SIZE
125 #if !defined(CONFIGURE_DISABLE_BSP_SETTINGS) && \
126 defined(BSP_IDLE_TASK_STACK_SIZE)
127 #define CONFIGURE_IDLE_TASK_STACK_SIZE BSP_IDLE_TASK_STACK_SIZE
128 #else
129 #define CONFIGURE_IDLE_TASK_STACK_SIZE CONFIGURE_MINIMUM_TASK_STACK_SIZE
130 #endif
131#endif
132
133#if CONFIGURE_IDLE_TASK_STACK_SIZE < CONFIGURE_MINIMUM_TASK_STACK_SIZE
134 #error "CONFIGURE_IDLE_TASK_STACK_SIZE less than CONFIGURE_MINIMUM_TASK_STACK_SIZE"
135#endif
136
138
139#if defined(CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION) && \
140 !defined(CONFIGURE_IDLE_TASK_BODY)
141 #error "If you define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION, then you must define CONFIGURE_IDLE_TASK_BODY as well"
142#endif
143
144#if !defined(CONFIGURE_IDLE_TASK_BODY) && \
145 !defined(CONFIGURE_DISABLE_BSP_SETTINGS) && defined(BSP_IDLE_TASK_BODY)
146 #define CONFIGURE_IDLE_TASK_BODY BSP_IDLE_TASK_BODY
147#endif
148
149#ifdef CONFIGURE_IDLE_TASK_BODY
151#endif
152
153#ifdef __cplusplus
154}
155#endif
156
157#endif /* CONFIGURE_INIT */
158
159#endif /* _RTEMS_CONFDEFS_PERCPU_H */
This header file provides the interfaces of the Context Handler.
This header file evaluates configuration options related to the BSP configuration.
This header file provides interfaces of the SMP Support which are used by the implementation and the ...
#define RTEMS_SYMBOL_NAME(_name)
Maps the name to the associated symbol name.
Definition: basedefs.h:861
#define RTEMS_SECTION(_section)
Instructs the compiler to place the variable or function in the section.
Definition: basedefs.h:411
#define RTEMS_ALIGNED(_alignment)
Instructs the compiler in a declaration or definition to enforce the alignment.
Definition: basedefs.h:157
#define RTEMS_DEFINE_GLOBAL_SYMBOL(_name, _value)
Defines a global symbol with the name and value.
Definition: basedefs.h:1015
This configuration option is an integer define.
Definition: appl-config.h:2871
Definition: appl-config.h:3602
This configuration option is an initializer define.
Definition: appl-config.h:3518
const char _ISR_Stack_area_end[]
The interrupt stack area end.
char _ISR_Stack_area_begin[]
The interrupt stack area begin.
CPU_STRUCTURE_ALIGNMENT Per_CPU_Control_envelope _Per_CPU_Information[]
Set of Per CPU Core Information.
Definition: asm.h:171
#define _SMP_Processor_configured_maximum
The configured processor maximum.
Definition: smp.h:68
void *(* Thread_Idle_body)(uintptr_t)
The idle thread body type.
Definition: threadidledata.h:64
const Thread_Idle_body _Thread_Idle_body
The idle thread body.
Definition: threadidledefault.c:44
const size_t _Thread_Idle_stack_size
The idle thread stack size in bytes.
This header file provides the interfaces of the Per-CPU Information.
Definition: percpu.h:650
