RTEMS 6.1
21#define COMLOCV(x) (*(volatile unsigned char *)(x))
23#define COMLOC_DEBUG_PRODUCE COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1000)
24#define COMLOC_DEBUG(offset) COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1001+offset)
25#define COMLOC_MEVT_PRODUCE COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1101)
26#define COMLOC_MEVT(offset) COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1102+offset)
27#define COMLOC_KEVT_PRODUCE COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1142)
28#define COMLOC_KEVT(offset) COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1143+offset)
29#define COMLOC_MIDI_PRODUCE COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1183)
30#define COMLOC_MIDI(offset) COMLOCV(MM_SOFTUSB_DMEM_BASE+0x1184+offset)
