RTEMS
6.1
bsps
sparc
leon3
include
bsp
irq.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* Copyright (c) 2012.
13
* Aeroflex Gaisler AB.
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef LIBBSP_LEON3_IRQ_CONFIG_H
38
#define LIBBSP_LEON3_IRQ_CONFIG_H
39
40
rtems.h
41
42
#define BSP_INTERRUPT_VECTOR_MAX_STD 15
/* Standard IRQ controller */
43
#define BSP_INTERRUPT_VECTOR_MAX_EXT 31
/* Extended IRQ controller */
44
45
#define BSP_INTERRUPT_VECTOR_COUNT (BSP_INTERRUPT_VECTOR_MAX_EXT + 1)
46
47
/* The check is different depending on IRQ controller, runtime detected */
48
#define BSP_INTERRUPT_CUSTOM_VALID_VECTOR
49
50
#endif
/* LIBBSP_LEON3_IRQ_CONFIG_H */
rtems.h
