RTEMS 6.1
bsp.h
2
11/* bsp.h
12 *
13 * This include file contains all SPARC64 simulator definitions.
14 *
15 * COPYRIGHT (c) 1989-1998. On-Line Applications Research Corporation (OAR).
16 *
17 * Redistribution and use in source and binary forms, with or without
18 * modification, are permitted provided that the following conditions
19 * are met:
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 * 2. Redistributions in binary form must reproduce the above copyright
23 * notice, this list of conditions and the following disclaimer in the
24 * documentation and/or other materials provided with the distribution.
25 *
26 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36 * POSSIBILITY OF SUCH DAMAGE.
37 *
38 */
39
40#ifndef LIBBSP_SPARC64_USIII_BSP_H
41#define LIBBSP_SPARC64_USIII_BSP_H
42
53#include <bspopts.h>
55
56#include <rtems.h>
57
58#ifdef __cplusplus
59extern "C" {
60#endif
61
62/* support for simulated clock tick */
63/*
64void *clock_driver_sim_idle_body(uintptr_t);
65#define BSP_IDLE_TASK_BODY clock_driver_sim_idle_body
66*/
67
68/* this should be defined somewhere */
69rtems_isr_entry set_vector( /* returns old vector */
70 rtems_isr_entry handler, /* isr routine */
71 rtems_vector_number vector, /* vector number */
72 int type /* RTEMS or RAW intr */
73);
74
75#ifdef __cplusplus
76}
77#endif
78
81#endif
This header file provides the default definition of BSP_INITIAL_EXTENSION.
ISR_Handler_entry rtems_isr_entry
Interrupt service routines installed by rtems_interrupt_catch() shall have this type.
Definition: intr.h:134
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
