RTEMS 6.1
bsp.h
1
9/*
10 * SH-gdb simulator BSP
11 *
12 * This include file contains all board IO definitions.
13 */
14
15/*
16 * Author: Ralf Corsepius (corsepiu@faw.uni-ulm.de)
17 *
18 * COPYRIGHT (c) 2001, Ralf Corsepius, Ulm, Germany
19 *
20 * This program is distributed in the hope that it will be useful,
21 * but WITHOUT ANY WARRANTY; without even the implied warranty of
22 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
23 *
24 * COPYRIGHT (c) 2001.
25 * On-Line Applications Research Corporation (OAR).
26 *
27 * The license and distribution terms for this file may be
28 * found in the file LICENSE in this distribution or at
29 * http://www.rtems.org/license/LICENSE.
30 */
31
32#ifndef LIBBSP_SH_SHSIM_BSP_H
33#define LIBBSP_SH_SHSIM_BSP_H
34
45#ifndef ASM
46
47#include <rtems.h>
48
49#include <bspopts.h>
51
52/*
53 * FIXME: One of these would be enough.
54 */
55#include <rtems/devnull.h>
56
57#ifdef __cplusplus
58extern "C" {
59#endif
60
61/* Constants */
62
63void *clock_driver_sim_idle_body(uintptr_t);
64#define BSP_IDLE_TASK_BODY clock_driver_sim_idle_body
65
66/*
67 * BSP methods that cross file boundaries.
68 */
69int _sys_exit (int n);
70void bsp_hw_init(void);
71
72#ifdef __cplusplus
73}
74#endif
75
76#endif /* !ASM */
77
80#endif
This header file provides the default definition of BSP_INITIAL_EXTENSION.
RTEMS /dev/null Device Driver.
