RTEMS 6.1
bsp.h
1
9/*
10 * generic sh1
11 *
12 * This include file contains all board IO definitions.
13 */
14
15/*
16 * Author: Ralf Corsepius (corsepiu@faw.uni-ulm.de)
17 *
18 * COPYRIGHT (c) 1997-1998, FAW Ulm, Germany
19 *
20 * This program is distributed in the hope that it will be useful,
21 * but WITHOUT ANY WARRANTY; without even the implied warranty of
22 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
23 *
24 *
25 * COPYRIGHT (c) 1998.
26 * On-Line Applications Research Corporation (OAR).
27 *
28 * The license and distribution terms for this file may be
29 * found in the file LICENSE in this distribution or at
30 * http://www.rtems.org/license/LICENSE.
31 */
32
33#ifndef LIBBSP_SH_GENSH1_BSP_H
34#define LIBBSP_SH_GENSH1_BSP_H
35
46#include <rtems.h>
47#include <termios.h> /* for tcflag_t */
48
49#include <bspopts.h>
51
52#ifdef __cplusplus
53extern "C" {
54#endif
55
56/* EDIT: To activate the sci driver, change the define below */
57#if 1
58#include <rtems/devnull.h>
59#define BSP_CONSOLE_DEVNAME "/dev/null"
60#define BSP_CONSOLE_DRIVER_TABLE_ENTRY DEVNULL_DRIVER_TABLE_ENTRY
61#else
62#include <sh/sci.h>
63#define BSP_CONSOLE_DEVNAME "/dev/sci0"
64#define BSP_CONSOLE_DRIVER_TABLE_ENTRY DEVSCI_DRIVER_TABLE_ENTRY
65#endif
66
67/* Constants */
68
69/*
70 * BSP methods that cross file boundaries.
71 */
72void bsp_hw_init(void);
73
74int _sci_get_brparms(
75 unsigned int spd,
76 unsigned char *smr,
77 unsigned char *brr
78);
79
80#ifdef __cplusplus
81}
82#endif
83
86#endif
This header file provides the default definition of BSP_INITIAL_EXTENSION.
RTEMS /dev/null Device Driver.
