RTEMS 6.1
bsp.h
2
11/*
12 *
13 * Copyright (c) 2015 University of York.
14 * Hesham Almatary <hesham@alumni.york.ac.uk>
15 *
16 * COPYRIGHT (c) 1989-1999.
17 * On-Line Applications Research Corporation (OAR).
18 *
19 * Redistribution and use in source and binary forms, with or without
20 * modification, are permitted provided that the following conditions
21 * are met:
22 * 1. Redistributions of source code must retain the above copyright
23 * notice, this list of conditions and the following disclaimer.
24 * 2. Redistributions in binary form must reproduce the above copyright
25 * notice, this list of conditions and the following disclaimer in the
26 * documentation and/or other materials provided with the distribution.
27 *
28 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
29 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
30 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
31 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
32 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
33 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
34 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
35 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
36 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
37 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
38 * SUCH DAMAGE.
39 */
40
41#ifndef LIBBSP_RISCV_GENERIC_H
42#define LIBBSP_RISCV_GENERIC_H
43
54#include <rtems.h>
55#include <rtems/clockdrv.h>
56#include <rtems/console.h>
57
58#include <bspopts.h>
60
61#include <rtems/devnull.h>
62
63#if RISCV_ENABLE_KENDRYTE_K210_SUPPORT != 0
64 #include <bsp/k210.h>
65#endif
66
67#ifdef __cplusplus
68extern "C" {
69#endif
70
71#define BSP_FEATURE_IRQ_EXTENSION
72
73#define BSP_FDT_IS_SUPPORTED
74
75#ifdef __cplusplus
76}
77#endif
78
81#endif /* LIBBSP_RISCV_GENERIC_H */
This header file defines the Clock Driver API.
Console Driver for all Boards.
This header file provides the default definition of BSP_INITIAL_EXTENSION.
RTEMS /dev/null Device Driver.
k210 RISC-V CPU defines.
