RTEMS 6.1
bsp.h
2
11/*
12 * Copyright (c) 2021 Cobham Gaisler AB.
13 *
14 * Copyright (c) 2015 University of York.
15 * Hesham Almatary <hesham@alumni.york.ac.uk>
16 *
17 * COPYRIGHT (c) 1989-1999.
18 * On-Line Applications Research Corporation (OAR).
19 *
20 * Redistribution and use in source and binary forms, with or without
21 * modification, are permitted provided that the following conditions
22 * are met:
23 * 1. Redistributions of source code must retain the above copyright
24 * notice, this list of conditions and the following disclaimer.
25 * 2. Redistributions in binary form must reproduce the above copyright
26 * notice, this list of conditions and the following disclaimer in the
27 * documentation and/or other materials provided with the distribution.
28 *
29 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
30 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
31 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
32 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
33 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
34 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
35 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
36 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
37 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
38 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
39 * SUCH DAMAGE.
40 */
41
42#ifndef LIBBSP_RISCV_NOEL_H
43#define LIBBSP_RISCV_NOEL_H
44
55#include <rtems.h>
56#include <rtems/clockdrv.h>
57#include <rtems/console.h>
58
59#include <bspopts.h>
61
62#include <rtems/devnull.h>
63
64#ifdef __cplusplus
65extern "C" {
66#endif
67
68#define BSP_FEATURE_IRQ_EXTENSION
69
70#define BSP_FDT_IS_SUPPORTED
71
72#ifdef __cplusplus
73}
74#endif
75
78#endif /* LIBBSP_RISCV_NOEL_H */
This header file defines the Clock Driver API.
Console Driver for all Boards.
This header file provides the default definition of BSP_INITIAL_EXTENSION.
RTEMS /dev/null Device Driver.
