RTEMS 6.1
riscv.h
2
3/*
4 * Copyright (c) 2018 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
16 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
19 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
20 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
21 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
22 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
23 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
24 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
25 * SUCH DAMAGE.
26 */
27
28#ifndef BSP_RISCV_H
29#define BSP_RISCV_H
30
31#include <bsp.h>
32
33#include <rtems/score/cpuimpl.h>
34
35#ifdef __cplusplus
36extern "C" {
37#endif
38
39extern volatile RISCV_CLINT_regs *riscv_clint;
40
41void *riscv_fdt_get_address(const void *fdt, int node);
42
43uint32_t riscv_get_core_frequency(void);
44
45#ifdef RTEMS_SMP
46extern uint32_t riscv_hart_count;
47#else
48#define riscv_hart_count 1
49#endif
50
51uint32_t riscv_get_hart_index_by_phandle(uint32_t phandle);
52
53#ifdef __cplusplus
54}
55#endif
56
57#endif /* BSP_RISCV_H */
Definition: cpuimpl.h:318
