RTEMS 6.1
io.h
2
11/*
12 * Copyright (C) 2021 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36/*
37 * This file is part of the RTEMS quality process and was automatically
38 * generated. If you find something that needs to be fixed or
39 * worded better please post a report or patch to an RTEMS mailing list
40 * or raise a bug report:
41 *
42 * https://www.rtems.org/bugs.html
43 *
44 * For information on updating and regenerating please refer to the How-To
45 * section in the Software Requirements Engineering chapter of the
46 * RTEMS Software Engineering manual. The manual is provided as a part of
47 * a release. For development sources please refer to the online
48 * documentation at:
49 *
50 * https://docs.rtems.org
51 */
52
53/* Generated from spec:/bsp/riscv/if/grlib-io-header */
54
55#ifndef _GRLIB_IO_H
56#define _GRLIB_IO_H
57
58#include <stdint.h>
59
60#ifdef __cplusplus
61extern "C" {
62#endif
63
64/* Generated from spec:/bsp/riscv/if/grlib-io-group */
65
74/* Generated from spec:/bsp/riscv/if/grlib-load-08 */
75
86static inline uint8_t grlib_load_8( const volatile uint8_t *address )
87{
88 return *address;
89}
90
91/* Generated from spec:/bsp/riscv/if/grlib-load-16 */
92
103static inline uint16_t grlib_load_16( const volatile uint16_t *address )
104{
105 return *address;
106}
107
108/* Generated from spec:/bsp/riscv/if/grlib-load-32 */
109
120static inline uint32_t grlib_load_32( const volatile uint32_t *address )
121{
122 return *address;
123}
124
125/* Generated from spec:/bsp/riscv/if/grlib-load-64 */
126
137static inline uint64_t grlib_load_64( const volatile uint64_t *address )
138{
139 return *address;
140}
141
142/* Generated from spec:/bsp/riscv/if/grlib-store-08 */
143
153static inline void grlib_store_8( volatile uint8_t *address, uint8_t value )
154{
155 *address = value;
156}
157
158/* Generated from spec:/bsp/riscv/if/grlib-store-16 */
159
169static inline void grlib_store_16( volatile uint16_t *address, uint16_t value )
170{
171 *address = value;
172}
173
174/* Generated from spec:/bsp/riscv/if/grlib-store-32 */
175
185static inline void grlib_store_32( volatile uint32_t *address, uint32_t value )
186{
187 *address = value;
188}
189
190/* Generated from spec:/bsp/riscv/if/grlib-store-64 */
191
201static inline void grlib_store_64( volatile uint64_t *address, uint64_t value )
202{
203 *address = value;
204}
205
206#ifdef __cplusplus
207}
208#endif
209
210#endif /* _GRLIB_IO_H */
