RTEMS 6.1
bsp.h
1
9/*
10 *
11 * Copyright (c) 2015 University of York.
12 * Hesham Almatary <hesham@alumni.york.ac.uk>
13 *
14 * COPYRIGHT (c) 1989-1999.
15 * On-Line Applications Research Corporation (OAR).
16 *
17 * Redistribution and use in source and binary forms, with or without
18 * modification, are permitted provided that the following conditions
19 * are met:
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 * 2. Redistributions in binary form must reproduce the above copyright
23 * notice, this list of conditions and the following disclaimer in the
24 * documentation and/or other materials provided with the distribution.
25 *
26 * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
27 * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29 * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
30 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
31 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
32 * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
33 * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
34 * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
35 * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
36 * SUCH DAMAGE.
37 */
38
39#ifndef LIBBSP_RISCV_GRISCV_H
40#define LIBBSP_RISCV_GRISCV_H
41
53#include <rtems.h>
54#include <rtems/clockdrv.h>
55#include <rtems/console.h>
56#include <rtems/irq-extension.h>
57
58#include <bspopts.h>
60
61#include <rtems/devnull.h>
62
63#ifdef __cplusplus
64extern "C" {
65#endif
66
67#define BSP_FEATURE_IRQ_EXTENSION
68
69/* Maximum supported APBUARTs by BSP */
70#define BSP_NUMBER_OF_TERMIOS_PORTS 8
71
72/*
73 * Network driver configuration for greth
74 */
75struct rtems_bsdnet_ifconfig;
76extern int rtems_griscv_greth_driver_attach(
77 struct rtems_bsdnet_ifconfig *config,
78 int attach
79);
80
81#define RTEMS_BSP_NETWORK_DRIVER_NAME "gr_eth1"
82#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_griscv_greth_driver_attach
83#define GRETH_SUPPORTED
84#define CPU_U32_FIX
85
86#ifdef __cplusplus
87}
88#endif
89
92#endif /* LIBBSP_RISCV_GRISCV_H */
This header file defines the Clock Driver API.
Console Driver for all Boards.
This header file provides the default definition of BSP_INITIAL_EXTENSION.
RTEMS /dev/null Device Driver.
This header file is provided for backward compatiblility.
Definition: deflate.c:114
