RTEMS 6.1
bsp.h
1
9/*
10 * This include file contains all Virtex4 board IO definitions.
11 */
12
13/*
14 * derived from helas403/include/bsp.h:
15 * Id: bsp.h,v 1.4 2001/06/18 17:01:48 joel Exp
16 * Author: Thomas Doerfler <td@imd.m.isar.de>
17 * IMD Ingenieurbuero fuer Microcomputertechnik
18 *
19 * Copyright (c) 1998 IMD Ingenieurbuero fuer Microcomputertechnik
20 *
21 * Changes from IMD are covered by the original distributions terms.
22 * This file has been derived from the papyrus BSP.
23 *
24 * Author: Andrew Bray <andy@i-cubed.co.uk>
25 *
26 * COPYRIGHT (c) 1995 by i-cubed ltd.
27 *
28 * To anyone who acknowledges that this file is provided "AS IS"
29 * without any express or implied warranty:
30 * permission to use, copy, modify, and distribute this file
31 * for any purpose is hereby granted without fee, provided that
32 * the above copyright notice and this notice appears in all
33 * copies, and that the name of i-cubed limited not be used in
34 * advertising or publicity pertaining to distribution of the
35 * software without specific, written prior permission.
36 * i-cubed limited makes no representations about the suitability
37 * of this software for any purpose.
38 *
39 * Derived from c/src/lib/libbsp/no_cpu/no_bsp/include/bsp.h
40 *
41 * COPYRIGHT (c) 1989-1999.
42 * On-Line Applications Research Corporation (OAR).
43 *
44 * The license and distribution terms for this file may be
45 * found in the file LICENSE in this distribution or at
46 * http://www.rtems.org/license/LICENSE.
47 *
48 */
49
50#ifndef LIBBSP_POWERPC_VIRTEX4_BSP_H
51#define LIBBSP_POWERPC_VIRTEX4_BSP_H
52
63#include <bspopts.h>
64
65/*
66 * confdefs.h overrides for this BSP:
67 * - Interrupt stack space is not minimum if defined.
68 */
69#define BSP_INTERRUPT_STACK_SIZE (16 * 1024)
70
71#ifdef ASM
72/* Definition of where to store registers in alignment handler */
73#define ALIGN_REGS 0x0140
74
75#else
76#include <rtems.h>
77
79
80#ifdef __cplusplus
81extern "C" {
82#endif
83
84/*
85 * Prototypes for BSP methods shared across file boundaries
86 */
87void zero_bss(void);
88
89#ifdef __cplusplus
90}
91#endif
92
93#endif /* ASM */
94
97#endif
This header file provides the default definition of BSP_INITIAL_EXTENSION.
