RTEMS
6.1
bsps
powerpc
tqm8xx
include
bsp
spi.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* RTEMS support for MPC8xx
5
6
* This file contains the MPC8xx SPI driver declarations.
7
8
9
10
* Copyright (c) 2009 embedded brains GmbH & Co. KG
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef _M8XX_SPIDRV_H
35
#define _M8XX_SPIDRV_H
36
37
#include <mpc8xx.h>
38
rtems/libi2c.h
39
rtems/irq.h
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
44
45
typedef
struct
m8xx_spi_softc
46
int
initialized;
47
rtems_id
irq_sema_id;
48
rtems_isr_entry
old_handler;
49
m8xxBufferDescriptor_t
*rx_bd;
50
*tx_bd;
51
m8xx_spi_softc_t
52
53
typedef
struct
54
rtems_libi2c_bus_t
bus_desc;
55
m8xx_spi_softc_t
softc;
56
m8xx_spi_desc_t
57
58
59
| Function: |
60
61
rtems_status_code
m8xx_spi_init
62
63
64
| Purpose: |
65
| initialize the driver |
66
67
| Input Parameters: |
68
69
rtems_libi2c_bus_t
*bh
/* bus specifier structure */
70
71
72
| Return Value: |
73
| o = ok or error code |
74
75
76
77
| Function: |
78
79
int
m8xx_spi_read_bytes
80
81
82
| Purpose: |
83
| receive some bytes from SPI device |
84
85
| Input Parameters: |
86
87
rtems_libi2c_bus_t
*bh,
88
unsigned
char
*buf,
/* buffer to store bytes */
89
int
len
/* number of bytes to receive */
90
91
92
| Return Value: |
93
| number of bytes received or (negative) error code |
94
95
96
97
| Function: |
98
99
int
m8xx_spi_write_bytes
100
101
102
| Purpose: |
103
| send some bytes to SPI device |
104
105
| Input Parameters: |
106
107
rtems_libi2c_bus_t
*bh,
108
unsigned
char
*buf,
/* buffer to send */
109
int
len
/* number of bytes to send */
110
111
112
113
| Return Value: |
114
| number of bytes sent or (negative) error code |
115
116
117
118
| Function: |
119
120
rtems_status_code
m8xx_spi_set_tfr_mode
121
122
123
| Purpose: |
124
| set SPI to desired baudrate/clock mode/character mode |
125
126
| Input Parameters: |
127
128
rtems_libi2c_bus_t
*bh,
129
const
rtems_libi2c_tfr_mode_t
*tfr_mode
/* transfer mode info */
130
131
132
| Return Value: |
133
| rtems_status_code |
134
135
136
137
| Function: |
138
139
int
m8xx_spi_ioctl
140
141
142
| Purpose: |
143
| perform selected ioctl function for SPI |
144
145
| Input Parameters: |
146
147
rtems_libi2c_bus_t
*bh,
148
int
cmd,
/* ioctl command code */
149
void
*arg
/* additional argument array */
150
151
152
| Return Value: |
153
| rtems_status_code |
154
155
156
#ifdef __cplusplus
157
158
#endif
159
160
161
#endif
/* _M8XX_SPIDRV_H */
irq.h
rtems_isr_entry
ISR_Handler_entry rtems_isr_entry
Interrupt service routines installed by rtems_interrupt_catch() shall have this type.
Definition:
intr.h:134
rtems_status_code
rtems_status_code
Definition:
status.h:85
rtems_id
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition:
types.h:94
libi2c.h
Legacy I2C Library.
Definition:
mpc8xx.h:676
m8xx_spi_desc_t
Definition:
spi.h:53
m8xx_spi_softc
Definition:
spi.h:45
rtems_libi2c_bus_t_
Definition:
libi2c.h:163
Definition:
libi2c.h:462
