RTEMS 6.1
bsp.h
2
11/*
12 * Copyright (C) 2012, 2017 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_POWERPC_T32MPPC_BSP_H
37#define LIBBSP_POWERPC_T32MPPC_BSP_H
38
49#include <bspopts.h>
50
51#ifndef ASM
52
53#include <rtems.h>
54
56
57#ifdef __cplusplus
58extern "C" {
59#endif /* __cplusplus */
60
61#define BSP_FEATURE_IRQ_EXTENSION
62
63extern uint32_t bsp_time_base_frequency;
64
65void t32mppc_decrementer_dispatch(void);
66
67#endif /* ASM */
68
69#ifdef __cplusplus
70}
71#endif /* __cplusplus */
72
75#endif /* LIBBSP_POWERPC_T32MPPC_BSP_H */
This header file provides the default definition of BSP_INITIAL_EXTENSION.
