RTEMS 6.1
powerpc.h
1
5/*
6 * This file contains definitions for the IBM/Motorola PowerPC
7 * family members.
8 *
9 * Author: Andrew Bray <andy@i-cubed.co.uk>
10 *
11 * COPYRIGHT (c) 1995 by i-cubed ltd.
12 *
13 * MPC860 support code was added by Jay Monkman <jmonkman@frasca.com>
14 * MPC8260 support added by Andy Dachs <a.dachs@sstl.co.uk>
15 * Surrey Satellite Technology Limited
16 *
17 * To anyone who acknowledges that this file is provided "AS IS"
18 * without any express or implied warranty:
19 * permission to use, copy, modify, and distribute this file
20 * for any purpose is hereby granted without fee, provided that
21 * the above copyright notice and this notice appears in all
22 * copies, and that the name of i-cubed limited not be used in
23 * advertising or publicity pertaining to distribution of the
24 * software without specific, written prior permission.
25 * i-cubed limited makes no representations about the suitability
26 * of this software for any purpose.
27 *
28 * Derived from c/src/exec/cpu/no_cpu/no_cpu.h:
29 *
30 * COPYRIGHT (c) 1989-1997.
31 * On-Line Applications Research Corporation (OAR).
32 *
33 * The license and distribution terms for this file may in
34 * the file LICENSE in this distribution or at
35 * http://www.rtems.org/license/LICENSE.
36 *
37 *
38 * Note:
39 * This file is included by both C and assembler code ( -DASM )
40 */
41
42
43#ifndef _RTEMS_POWERPC_POWERPC_H
44#define _RTEMS_POWERPC_POWERPC_H
45
46#ifdef __cplusplus
47extern "C" {
48#endif
49
50
51/* Till S. 2008/07/10:
52 *
53 * Using the macros/definitions which depend on a preprocessor
54 * symbol defining the CPU flavor is discouraged.
55 * I recommend to not use definitions from this file and
56 * in particular - not to add more bits and pieces.
57 *
58 * Instead, try to use run-time detection (see e.g. cpuIdent.c/cpuIdent.h)
59 * of features etc.
60 */
61
62#include <rtems/score/powerpc.h>
63
64/*
65 * Unfortunately it is very inefficient to use run-time detection for the cache
66 * line size, so give the BSP the opportunity to define it here.
67 */
68#include <bspopts.h>
69
70/*
71 * This file contains the information required to build
72 * RTEMS for a particular member of the PowerPC family. It does
73 * this by setting variables to indicate which implementation
74 * dependent features are present in a particular member
75 * of the family.
76 *
77 * The following architectural feature definitions are defaulted
78 * unless specifically set by the model definition:
79 *
80 * + PPC_INTERRUPT_MAX - 16
81 * + PPC_CACHE_ALIGNMENT
82 * + PPC_LOW_POWER_MODE - PPC_LOW_POWER_MODE_NONE
83 * + PPC_HAS_EXCEPTION_PREFIX - 1
84 * + PPC_USE_MULTIPLE - 0
85 */
86
87/*
88 * Define the low power mode models
89 *
90 * Standard: as defined for 603e
91 * Nap Mode: nap mode only (604)
92 * XXX 403GB, 603, 603e, 604, 821
93 */
94
95#define PPC_LOW_POWER_MODE_NONE 0
96#define PPC_LOW_POWER_MODE_STANDARD 1
97
101#define PPC_NO_CACHE_ALIGNMENT 4
102
107#define PPC_NO_CACHE_ALIGNMENT_POWER 2
108
109/*
110 * Figure out all CPU Model Feature Flags based upon compiler
111 * predefines.
112 */
113
114/*
115 * FIXME: The ppc405 define must be checked before the ppc403 define. The
116 * ppc405 define is provided by <bspopts.h>. The ppc403 define is provided by
117 * GCC as a built-in define if no ppc* or mpc* define is set via the
118 * command line (see GCC sources "gcc/config/rs6000/rtems.h").
119 */
120#if defined(ppc405)
121
122#define PPC_CACHE_ALIGNMENT 32
123#define PPC_HAS_RI 0
124#define PPC_HAS_RFCI 1
125#define PPC_USE_MULTIPLE 1
126#define PPC_I_CACHE 16384
127#define PPC_D_CACHE 16384 /* except GP/CR */
128#define PPC_HAS_EXCEPTION_PREFIX 0
129#define PPC_HAS_EVPR 1
130
131#elif defined(ppc403)
132/*
133 * IBM 403
134 *
135 * Developed for 403GA. Book checked for 403GB.
136 *
137 * Does not have user mode.
138 */
139
140#define PPC_CACHE_ALIGNMENT 16
141#define PPC_HAS_RI 0
142#define PPC_HAS_RFCI 1
143#define PPC_USE_MULTIPLE 1
144#define PPC_I_CACHE 2048
145#define PPC_D_CACHE 1024
146
147#define PPC_HAS_EXCEPTION_PREFIX 0
148#define PPC_HAS_EVPR 1
149
150#elif defined (ppc440)
151
152#define PPC_CACHE_ALIGNMENT 32
153#define PPC_HAS_RI 0
154#define PPC_HAS_RFCI 1
155#define PPC_USE_MULTIPLE 1
156#define PPC_I_CACHE 32768
157#define PPC_D_CACHE 32768
158#define PPC_HAS_EXCEPTION_PREFIX 0
159#define PPC_HAS_EVPR 1
160
161#elif defined(mpc555)
162
163/* Copied from mpc505 */
164#define PPC_CACHE_ALIGNMENT PPC_NO_CACHE_ALIGNMENT
165
166/* Added by querbach@realtime.bc.ca */
167#define PPC_LOW_POWER_MODE PPC_LOW_POWER_MODE_STANDARD
168
169/* Based on comments by Sergei Organov <osv@Javad.RU> */
170#define PPC_I_CACHE 0
171#define PPC_D_CACHE 0
172
173#elif defined(mpc505) || defined(mpc509)
174/*
175 * Submitted by Sergei Organov <osv@Javad.RU> as a patch against
176 * 3.6.0 long after 4.0 was released. This is just an attempt
177 * to get the setting correct.
178 */
179
180#define CPU_MODEL_NAME "PowerPC 505/509"
181
182#define PPC_CACHE_ALIGNMENT PPC_NO_CACHE_ALIGNMENT
183#define PPC_I_CACHE 4096
184#define PPC_D_CACHE 0
185
186
187#elif defined(ppc601)
188
189/*
190 * Submitted with original port -- book checked only.
191 */
192
193#define PPC_USE_MULTIPLE 1
194#define PPC_I_CACHE 0
195#define PPC_D_CACHE 32768
196
197#elif defined(ppc603)
198/*
199 * Submitted with original port -- book checked only.
200 */
201
202#define PPC_I_CACHE 8192
203#define PPC_D_CACHE 8192
204
205#elif defined(ppc603e)
206
207/*
208 * Submitted with original port.
209 *
210 * Known to work on real hardware.
211 */
212
213#define PPC_I_CACHE 16384
214#define PPC_D_CACHE 16384
215
216#define PPC_LOW_POWER_MODE PPC_LOW_POWER_MODE_STANDARD
217
218#elif defined(mpc604)
219/*
220 * Submitted with original port -- book checked only.
221 */
222
223#define PPC_I_CACHE 16384
224#define PPC_D_CACHE 16384
225
226#elif defined(mpc860)
227/*
228 * Added by Jay Monkman (jmonkman@frasca.com) 6/28/98
229 * with some changes by Darlene Stewart (Darlene.Stewart@iit.nrc.ca)
230 */
231#define PPC_I_CACHE 4096
232#define PPC_D_CACHE 4096
233#define PPC_CACHE_ALIGNMENT 16
234#define PPC_INTERRUPT_MAX 71
235#define PPC_USE_MULTIPLE 1
236
237#define PPC_MSR_0 0x00009000
238#define PPC_MSR_1 0x00001000
239#define PPC_MSR_2 0x00001000
240#define PPC_MSR_3 0x00000000
241
242#elif defined(mpc821)
243/*
244 * Added by Andrew Bray <andy@chaos.org.uk> 6/April/1999
245 */
246#define PPC_I_CACHE 4096
247#define PPC_D_CACHE 4096
248#define PPC_CACHE_ALIGNMENT 16
249#define PPC_INTERRUPT_MAX 71
250
251#define PPC_MSR_0 0x00009000
252#define PPC_MSR_1 0x00001000
253#define PPC_MSR_2 0x00001000
254#define PPC_MSR_3 0x00000000
255
256#elif defined(mpc750)
257
258#define PPC_I_CACHE 16384
259#define PPC_D_CACHE 16384
260
261#elif defined(mpc7400)
262
263#define PPC_I_CACHE 32768
264#define PPC_D_CACHE 32768
265
266#elif defined(mpc7455)
267/*
268 * Added by S.K. Feng <feng1@bnl.gov> 10/03
269 */
270
271#define PPC_CACHE_ALIGNMENT 32
272#define PPC_I_CACHE 32768
273#define PPC_D_CACHE 32768
274
275#elif defined(mpc8260)
276/*
277 * Added by Andy Dachs <a.dachs@sstl.co.uk> 23/11/2000
278 */
279#define PPC_I_CACHE 16384
280#define PPC_D_CACHE 16384
281#define PPC_CACHE_ALIGNMENT 32
282#define PPC_INTERRUPT_MAX 125
283#define PPC_USE_MULTIPLE 1
284
285#endif
286
287/*
288 * If the maximum number of exception sources has not been defined,
289 * then default it to 16.
290 */
291
292#ifndef PPC_INTERRUPT_MAX
293#define PPC_INTERRUPT_MAX 16
294#endif
295
296#ifndef PPC_CACHE_ALIGNMENT
297#define PPC_CACHE_ALIGNMENT PPC_DEFAULT_CACHE_LINE_SIZE
298#endif
299
300#if (PPC_CACHE_ALIGNMENT == 16)
301#define PPC_CACHE_ALIGN_POWER 4
302#elif (PPC_CACHE_ALIGNMENT == 32)
303#define PPC_CACHE_ALIGN_POWER 5
304#elif (PPC_CACHE_ALIGNMENT == 64)
305#define PPC_CACHE_ALIGN_POWER 6
306#elif (PPC_CACHE_ALIGNMENT == PPC_NO_CACHE_ALIGNMENT)
307#define PPC_CACHE_ALIGN_POWER PPC_NO_CACHE_ALIGNMENT_POWER
308#else
309#error "Undefined power of 2 for PPC_CACHE_ALIGNMENT"
310#endif
311
312/*
313 * Unless otherwise specified, assume the model has an IP/EP bit to
314 * set the exception address prefix.
315 */
316
317#ifndef PPC_HAS_EXCEPTION_PREFIX
318#define PPC_HAS_EXCEPTION_PREFIX 1
319#endif
320/*
321 * Unless otherwise specified, assume the model has an RI bit to
322 * identify non-recoverable interrupts
323 */
324
325#ifndef PPC_HAS_RI
326#define PPC_HAS_RI 1
327#endif
328
329/*
330 * Unless otherwise specified, assume the model does NOT have
331 * 403 style EVPR register to set the exception address prefix.
332 */
333
334#ifndef PPC_HAS_EVPR
335#define PPC_HAS_EVPR 0
336#endif
337
338/*
339 * If no low power mode model was specified, then assume there is none.
340 */
341
342#ifndef PPC_LOW_POWER_MODE
343#define PPC_LOW_POWER_MODE PPC_LOW_POWER_MODE_NONE
344#endif
345
346/*
347 * Unless specified above, then assume the model does NOT have critical
348 * interrupt support.
349 */
350
351#ifndef PPC_HAS_RFCI
352#define PPC_HAS_RFCI 0
353#endif
354
355/*
356 * Unless specified above, do not use the load/store multiple instructions
357 * in a context switch.
358 */
359
360#ifndef PPC_USE_MULTIPLE
361#define PPC_USE_MULTIPLE 0
362#endif
363
364/*
365 * The following exceptions are not maskable, and are not
366 * necessarily predictable, so cannot be offered to RTEMS:
367 * Alignment exception - handled by the CPU module
368 * Data exceptions.
369 * Instruction exceptions.
370 */
371
372/*
373 * Base Interrupt vectors supported on all models.
374 */
375#define PPC_IRQ_SYSTEM_RESET 0 /* 0x00100 - System reset. */
376#define PPC_IRQ_MCHECK 1 /* 0x00200 - Machine check */
377#define PPC_IRQ_PROTECT 2 /* 0x00300 - Protection violation */
378#define PPC_IRQ_ISI 3 /* 0x00400 - Instruction Fetch error */
379#define PPC_IRQ_EXTERNAL 4 /* 0x00500 - External interrupt */
380#define PPC_IRQ_ALIGNMENT 5 /* 0X00600 - Alignment exception */
381#define PPC_IRQ_PROGRAM 6 /* 0x00700 - Program exception */
382#define PPC_IRQ_NOFP 7 /* 0x00800 - Floating point unavailable */
383#define PPC_IRQ_DECREMENTER 8 /* 0x00900 - Decrementer interrupt */
384#define PPC_IRQ_RESERVED_A 9 /* 0x00a00 - Implementation Reserved */
385#define PPC_IRQ_RESERVED_B 10 /* 0x00b00 - Implementation Reserved */
386#define PPC_IRQ_SCALL 11 /* 0x00c00 - System call */
387#define PPC_IRQ_TRACE 12 /* 0x00d00 - Trace Exception */
388#define PPC_IRQ_FP_ASST 13 /* ox00e00 - Floating point assist */
389#define PPC_STD_IRQ_LAST PPC_IRQ_FP_ASST
390
391#define PPC_IRQ_FIRST PPC_IRQ_SYSTEM_RESET
392
393#if defined(ppc403) || defined(ppc405) || defined(ppc440)
394
395#define PPC_IRQ_CRIT PPC_IRQ_SYSTEM_RESET /*0x00100- Critical int. pin */
396#define PPC_IRQ_PIT (PPC_STD_IRQ_LAST+1) /*0x01000- Pgm interval timer*/
397#define PPC_IRQ_FIT (PPC_STD_IRQ_LAST+2) /*0x01010- Fixed int. timer */
398#define PPC_IRQ_WATCHDOG (PPC_STD_IRQ_LAST+3) /*0x01020- Watchdog timer */
399#define PPC_IRQ_DEBUG (PPC_STD_IRQ_LAST+4) /*0x02000- Debug exceptions */
400#define PPC_IRQ_LAST PPC_IRQ_DEBUG
401
402#elif defined(mpc505) || defined(mpc509)
403#define PPC_IRQ_SOFTEMU (PPC_STD_IRQ_LAST+1) /* Software emulation. */
404#define PPC_IRQ_DATA_BP (PPC_STD_IRQ_LAST+ 2)
405#define PPC_IRQ_INST_BP (PPC_STD_IRQ_LAST+ 3)
406#define PPC_IRQ_MEXT_BP (PPC_STD_IRQ_LAST+ 4)
407#define PPC_IRQ_NMEXT_BP (PPC_STD_IRQ_LAST+ 5)
408
409#elif defined(mpc555)
410#define PPC_IRQ_SOFTEMU (PPC_STD_IRQ_LAST+1) /* Software emulation. */
411#define PPC_IRQ_INST_PE (PPC_STD_IRQ_LAST+2) /* Insn protection error */
412#define PPC_IRQ_DATA_PE (PPC_STD_IRQ_LAST+3) /* Data protection error */
413#define PPC_IRQ_DATA_BP (PPC_STD_IRQ_LAST+4) /* Data breakpoint */
414#define PPC_IRQ_INST_BP (PPC_STD_IRQ_LAST+5) /* Insn breakpoint */
415#define PPC_IRQ_MEXT_BP (PPC_STD_IRQ_LAST+6) /* Maskable ext bkpt */
416#define PPC_IRQ_NMEXT_BP (PPC_STD_IRQ_LAST+7) /* Non-maskable ext bkpt */
417#define PPC_IRQ_LAST PPC_IRQ_NMEXT_BP
418
419#elif defined(ppc601)
420#undef PPC_IRQ_TRACE
421#define PPC_IRQ_TRACE (PPC_STD_IRQ_LAST+1) /*0x02000-Run/Trace Exception*/
422#define PPC_IRQ_LAST PPC_IRQ_TRACE
423
424#elif defined(ppc602)
425#define PPC_IRQ_LAST (PPC_STD_IRQ_LAST)
426
427#elif defined(ppc603) || defined(ppc603e)
428#define PPC_IRQ_TRANS_MISS (PPC_STD_IRQ_LAST+1) /*0x1000-Ins Translation Miss*/
429#define PPC_IRQ_DATA_LOAD (PPC_STD_IRQ_LAST+2) /*0x1100-Data Load Trans Miss*/
430#define PPC_IRQ_DATA_STORE (PPC_STD_IRQ_LAST+3) /*0x1200-Data Store Miss */
431#define PPC_IRQ_ADDR_BRK (PPC_STD_IRQ_LAST+4) /*0x1300-Instruction Bkpoint */
432#define PPC_IRQ_SYS_MGT (PPC_STD_IRQ_LAST+5) /*0x1400-System Management */
433#define PPC_IRQ_LAST PPC_IRQ_SYS_MGT
434
435#elif defined(mpc604)
436#define PPC_IRQ_ADDR_BRK (PPC_STD_IRQ_LAST+1) /*0x1300- Inst. addr break */
437#define PPC_IRQ_SYS_MGT (PPC_STD_IRQ_LAST+2) /*0x1400- System Management */
438#define PPC_IRQ_LAST PPC_IRQ_SYS_MGT
439
440#elif defined(mpc860) || defined(mpc821)
441#define PPC_IRQ_EMULATE (PPC_STD_IRQ_LAST+1) /*0x1000-Software emulation */
442#define PPC_IRQ_INST_MISS (PPC_STD_IRQ_LAST+2) /*0x1100-Instruction TLB miss*/
443#define PPC_IRQ_DATA_MISS (PPC_STD_IRQ_LAST+3) /*0x1200-Data TLB miss */
444#define PPC_IRQ_INST_ERR (PPC_STD_IRQ_LAST+4) /*0x1300-Instruction TLB err */
445#define PPC_IRQ_DATA_ERR (PPC_STD_IRQ_LAST+5) /*0x1400-Data TLB error */
446#define PPC_IRQ_DATA_BPNT (PPC_STD_IRQ_LAST+6) /*0x1C00-Data breakpoint */
447#define PPC_IRQ_INST_BPNT (PPC_STD_IRQ_LAST+7) /*0x1D00-Inst breakpoint */
448#define PPC_IRQ_IO_BPNT (PPC_STD_IRQ_LAST+8) /*0x1E00-Peripheral breakpnt */
449#define PPC_IRQ_DEV_PORT (PPC_STD_IRQ_LAST+9) /*0x1F00-Development port */
450#define PPC_IRQ_IRQ0 (PPC_STD_IRQ_LAST + 10)
451#define PPC_IRQ_LVL0 (PPC_STD_IRQ_LAST + 11)
452#define PPC_IRQ_IRQ1 (PPC_STD_IRQ_LAST + 12)
453#define PPC_IRQ_LVL1 (PPC_STD_IRQ_LAST + 13)
454#define PPC_IRQ_IRQ2 (PPC_STD_IRQ_LAST + 14)
455#define PPC_IRQ_LVL2 (PPC_STD_IRQ_LAST + 15)
456#define PPC_IRQ_IRQ3 (PPC_STD_IRQ_LAST + 16)
457#define PPC_IRQ_LVL3 (PPC_STD_IRQ_LAST + 17)
458#define PPC_IRQ_IRQ4 (PPC_STD_IRQ_LAST + 18)
459#define PPC_IRQ_LVL4 (PPC_STD_IRQ_LAST + 19)
460#define PPC_IRQ_IRQ5 (PPC_STD_IRQ_LAST + 20)
461#define PPC_IRQ_LVL5 (PPC_STD_IRQ_LAST + 21)
462#define PPC_IRQ_IRQ6 (PPC_STD_IRQ_LAST + 22)
463#define PPC_IRQ_LVL6 (PPC_STD_IRQ_LAST + 23)
464#define PPC_IRQ_IRQ7 (PPC_STD_IRQ_LAST + 24)
465#define PPC_IRQ_LVL7 (PPC_STD_IRQ_LAST + 25)
466#define PPC_IRQ_CPM_ERROR (PPC_STD_IRQ_LAST + 26)
467#define PPC_IRQ_CPM_PC4 (PPC_STD_IRQ_LAST + 27)
468#define PPC_IRQ_CPM_PC5 (PPC_STD_IRQ_LAST + 28)
469#define PPC_IRQ_CPM_SMC2 (PPC_STD_IRQ_LAST + 29)
470#define PPC_IRQ_CPM_SMC1 (PPC_STD_IRQ_LAST + 30)
471#define PPC_IRQ_CPM_SPI (PPC_STD_IRQ_LAST + 31)
472#define PPC_IRQ_CPM_PC6 (PPC_STD_IRQ_LAST + 32)
473#define PPC_IRQ_CPM_TIMER4 (PPC_STD_IRQ_LAST + 33)
474#define PPC_IRQ_CPM_RESERVED_8 (PPC_STD_IRQ_LAST + 34)
475#define PPC_IRQ_CPM_PC7 (PPC_STD_IRQ_LAST + 35)
476#define PPC_IRQ_CPM_PC8 (PPC_STD_IRQ_LAST + 36)
477#define PPC_IRQ_CPM_PC9 (PPC_STD_IRQ_LAST + 37)
478#define PPC_IRQ_CPM_TIMER3 (PPC_STD_IRQ_LAST + 38)
479#define PPC_IRQ_CPM_RESERVED_D (PPC_STD_IRQ_LAST + 39)
480#define PPC_IRQ_CPM_PC10 (PPC_STD_IRQ_LAST + 40)
481#define PPC_IRQ_CPM_PC11 (PPC_STD_IRQ_LAST + 41)
482#define PPC_IRQ_CPM_I2C (PPC_STD_IRQ_LAST + 42)
483#define PPC_IRQ_CPM_RISC_TIMER (PPC_STD_IRQ_LAST + 43)
484#define PPC_IRQ_CPM_TIMER2 (PPC_STD_IRQ_LAST + 44)
485#define PPC_IRQ_CPM_RESERVED_13 (PPC_STD_IRQ_LAST + 45)
486#define PPC_IRQ_CPM_IDMA2 (PPC_STD_IRQ_LAST + 46)
487#define PPC_IRQ_CPM_IDMA1 (PPC_STD_IRQ_LAST + 47)
488#define PPC_IRQ_CPM_SDMA_ERROR (PPC_STD_IRQ_LAST + 48)
489#define PPC_IRQ_CPM_PC12 (PPC_STD_IRQ_LAST + 49)
490#define PPC_IRQ_CPM_PC13 (PPC_STD_IRQ_LAST + 50)
491#define PPC_IRQ_CPM_TIMER1 (PPC_STD_IRQ_LAST + 51)
492#define PPC_IRQ_CPM_PC14 (PPC_STD_IRQ_LAST + 52)
493#define PPC_IRQ_CPM_SCC4 (PPC_STD_IRQ_LAST + 53)
494#define PPC_IRQ_CPM_SCC3 (PPC_STD_IRQ_LAST + 54)
495#define PPC_IRQ_CPM_SCC2 (PPC_STD_IRQ_LAST + 55)
496#define PPC_IRQ_CPM_SCC1 (PPC_STD_IRQ_LAST + 56)
497#define PPC_IRQ_CPM_PC15 (PPC_STD_IRQ_LAST + 57)
498
499#define PPC_IRQ_LAST PPC_IRQ_CPM_PC15
500
501#elif defined(mpc8260)
502
503#define PPC_IRQ_INST_MISS (PPC_STD_IRQ_LAST+1) /*0x1000-Instruction TLB miss*/
504#define PPC_IRQ_DATA_MISS (PPC_STD_IRQ_LAST+2) /*0x1100-Data TLB miss */
505#define PPC_IRQ_DATA_L_MISS (PPC_STD_IRQ_LAST+3) /*0x1200-Data TLB load miss */
506#define PPC_IRQ_DATA_S_MISS (PPC_STD_IRQ_LAST+4) /*0x1300-Data TLB store miss */
507#define PPC_IRQ_INST_BPNT (PPC_STD_IRQ_LAST+5) /*0x1400-Inst address breakpoint */
508#define PPC_IRQ_SYS_MGT (PPC_STD_IRQ_LAST+6) /*0x1500-System Management */
509/* 0x1600 - 0x2F00 reserved */
510#define PPC_IRQ_CPM_NONE (PPC_STD_IRQ_LAST + 50)
511#define PPC_IRQ_CPM_I2C (PPC_STD_IRQ_LAST + 51)
512#define PPC_IRQ_CPM_SPI (PPC_STD_IRQ_LAST + 52)
513#define PPC_IRQ_CPM_RISC_TIMER (PPC_STD_IRQ_LAST + 53)
514#define PPC_IRQ_CPM_SMC1 (PPC_STD_IRQ_LAST + 54)
515#define PPC_IRQ_CPM_SMC2 (PPC_STD_IRQ_LAST + 55)
516#define PPC_IRQ_CPM_IDMA1 (PPC_STD_IRQ_LAST + 56)
517#define PPC_IRQ_CPM_IDMA2 (PPC_STD_IRQ_LAST + 57)
518#define PPC_IRQ_CPM_IDMA3 (PPC_STD_IRQ_LAST + 58)
519#define PPC_IRQ_CPM_IDMA4 (PPC_STD_IRQ_LAST + 59)
520#define PPC_IRQ_CPM_SDMA (PPC_STD_IRQ_LAST + 60)
521#define PPC_IRQ_CPM_RES_A (PPC_STD_IRQ_LAST + 61)
522#define PPC_IRQ_CPM_TIMER1 (PPC_STD_IRQ_LAST + 62)
523#define PPC_IRQ_CPM_TIMER2 (PPC_STD_IRQ_LAST + 63)
524#define PPC_IRQ_CPM_TIMER3 (PPC_STD_IRQ_LAST + 64)
525#define PPC_IRQ_CPM_TIMER4 (PPC_STD_IRQ_LAST + 65)
526#define PPC_IRQ_CPM_TMCNT (PPC_STD_IRQ_LAST + 66)
527#define PPC_IRQ_CPM_PIT (PPC_STD_IRQ_LAST + 67)
528#define PPC_IRQ_CPM_RES_B (PPC_STD_IRQ_LAST + 68)
529#define PPC_IRQ_CPM_IRQ1 (PPC_STD_IRQ_LAST + 69)
530#define PPC_IRQ_CPM_IRQ2 (PPC_STD_IRQ_LAST + 70)
531#define PPC_IRQ_CPM_IRQ3 (PPC_STD_IRQ_LAST + 71)
532#define PPC_IRQ_CPM_IRQ4 (PPC_STD_IRQ_LAST + 72)
533#define PPC_IRQ_CPM_IRQ5 (PPC_STD_IRQ_LAST + 73)
534#define PPC_IRQ_CPM_IRQ6 (PPC_STD_IRQ_LAST + 74)
535#define PPC_IRQ_CPM_IRQ7 (PPC_STD_IRQ_LAST + 75)
536#define PPC_IRQ_CPM_RES_C (PPC_STD_IRQ_LAST + 76)
537#define PPC_IRQ_CPM_RES_D (PPC_STD_IRQ_LAST + 77)
538#define PPC_IRQ_CPM_RES_E (PPC_STD_IRQ_LAST + 78)
539#define PPC_IRQ_CPM_RES_F (PPC_STD_IRQ_LAST + 79)
540#define PPC_IRQ_CPM_RES_G (PPC_STD_IRQ_LAST + 80)
541#define PPC_IRQ_CPM_RES_H (PPC_STD_IRQ_LAST + 81)
542#define PPC_IRQ_CPM_FCC1 (PPC_STD_IRQ_LAST + 82)
543#define PPC_IRQ_CPM_FCC2 (PPC_STD_IRQ_LAST + 83)
544#define PPC_IRQ_CPM_FCC3 (PPC_STD_IRQ_LAST + 84)
545#define PPC_IRQ_CPM_RES_I (PPC_STD_IRQ_LAST + 85)
546#define PPC_IRQ_CPM_MCC1 (PPC_STD_IRQ_LAST + 86)
547#define PPC_IRQ_CPM_MCC2 (PPC_STD_IRQ_LAST + 87)
548#define PPC_IRQ_CPM_RES_J (PPC_STD_IRQ_LAST + 88)
549#define PPC_IRQ_CPM_RES_K (PPC_STD_IRQ_LAST + 89)
550#define PPC_IRQ_CPM_SCC1 (PPC_STD_IRQ_LAST + 90)
551#define PPC_IRQ_CPM_SCC2 (PPC_STD_IRQ_LAST + 91)
552#define PPC_IRQ_CPM_SCC3 (PPC_STD_IRQ_LAST + 92)
553#define PPC_IRQ_CPM_SCC4 (PPC_STD_IRQ_LAST + 93)
554#define PPC_IRQ_CPM_RES_L (PPC_STD_IRQ_LAST + 94)
555#define PPC_IRQ_CPM_RES_M (PPC_STD_IRQ_LAST + 95)
556#define PPC_IRQ_CPM_RES_N (PPC_STD_IRQ_LAST + 96)
557#define PPC_IRQ_CPM_RES_O (PPC_STD_IRQ_LAST + 97)
558#define PPC_IRQ_CPM_PC15 (PPC_STD_IRQ_LAST + 98)
559#define PPC_IRQ_CPM_PC14 (PPC_STD_IRQ_LAST + 99)
560#define PPC_IRQ_CPM_PC13 (PPC_STD_IRQ_LAST + 100)
561#define PPC_IRQ_CPM_PC12 (PPC_STD_IRQ_LAST + 101)
562#define PPC_IRQ_CPM_PC11 (PPC_STD_IRQ_LAST + 102)
563#define PPC_IRQ_CPM_PC10 (PPC_STD_IRQ_LAST + 103)
564#define PPC_IRQ_CPM_PC9 (PPC_STD_IRQ_LAST + 104)
565#define PPC_IRQ_CPM_PC8 (PPC_STD_IRQ_LAST + 105)
566#define PPC_IRQ_CPM_PC7 (PPC_STD_IRQ_LAST + 106)
567#define PPC_IRQ_CPM_PC6 (PPC_STD_IRQ_LAST + 107)
568#define PPC_IRQ_CPM_PC5 (PPC_STD_IRQ_LAST + 108)
569#define PPC_IRQ_CPM_PC4 (PPC_STD_IRQ_LAST + 109)
570#define PPC_IRQ_CPM_PC3 (PPC_STD_IRQ_LAST + 110)
571#define PPC_IRQ_CPM_PC2 (PPC_STD_IRQ_LAST + 111)
572#define PPC_IRQ_CPM_PC1 (PPC_STD_IRQ_LAST + 112)
573#define PPC_IRQ_CPM_PC0 (PPC_STD_IRQ_LAST + 113)
574
575#define PPC_IRQ_LAST PPC_IRQ_CPM_PC0
576
577#endif
578
579
580/*
581 * If the maximum number of exception sources is too low,
582 * then fix it
583 */
584
585#if PPC_INTERRUPT_MAX <= PPC_IRQ_LAST
586#undef PPC_INTERRUPT_MAX
587#define PPC_INTERRUPT_MAX ((PPC_IRQ_LAST) + 1)
588#endif
589
590/*
591 * Machine Status Register (MSR) Constants Used by RTEMS
592 */
593
594#if PPC_HAS_RI
595#define PPC_MSR_RI 0x000000002 /* bit 30 - recoverable exception */
596#endif
597
598#define PPC_MSR_DR 0x000000010 /* bit 27 - data address translation */
599#define PPC_MSR_IR 0x000000020 /* bit 26 - instruction addr translation*/
600
601/*
602 * Some PPC model manuals refer to the Exception Prefix (EP) bit as
603 * IP for no apparent reason.
604 */
605#if (PPC_HAS_EXCEPTION_PREFIX)
606#define PPC_MSR_EP 0x000000040 /* bit 25 - exception prefix */
607#else
608#define PPC_MSR_EP 0x000000000 /* bit 25 - exception prefix */
609#endif
610
611#if (PPC_HAS_FPU)
612#define PPC_MSR_FP 0x000002000 /* bit 18 - floating point enable */
613#else
614#define PPC_MSR_FP 0x000000000 /* bit 18 - floating point enable */
615#endif
616
617#if (PPC_LOW_POWER_MODE == PPC_LOW_POWER_MODE_NONE)
618#define PPC_MSR_POW 0x000000000 /* bit 13 - power management enable */
619#else
620#define PPC_MSR_POW 0x000040000 /* bit 13 - power management enable */
621#endif
622
623#define PPC_MSR_ME 0x000001000 /* bit 19 - machine check enable */
624#define PPC_MSR_EE 0x000008000 /* bit 16 - external interrupt enable */
625
626#if (PPC_HAS_RFCI)
627#define PPC_MSR_CE 0x000020000 /* bit 14 - critical interrupt enable */
628#else
629#define PPC_MSR_CE 0x000000000 /* bit 14 - critical interrupt enable */
630#endif
631
632#define PPC_MSR_DISABLE_MASK (PPC_MSR_ME|PPC_MSR_EE|PPC_MSR_CE)
633
634#if defined(__powerpc64__)
635#define PPC_MINIMUM_STACK_FRAME_SIZE 32
636#else
637#define PPC_MINIMUM_STACK_FRAME_SIZE PPC_STACK_ALIGNMENT
638#endif
639
640#ifdef __cplusplus
641}
642#endif
643
644#endif /* _RTEMS_POWERPC_POWERPC_H */
IBM/Motorola PowerPC Definitions.
