RTEMS 6.1
console.h
1#ifndef _MPC8260_CONSOLE_H
2#define _MPC8260_CONSOLE_H
3
4#include <rtems/libio.h>
5
6void m8xx_uart_initialize(void);
7void m8xx_uart_interrupts_initialize(void);
8void m8xx_uart_scc_initialize (int minor);
9void m8xx_uart_smc_initialize (int minor);
10
11/* Termios callbacks */
12int m8xx_uart_pollRead(int minor);
13ssize_t m8xx_uart_pollWrite(int minor, const char* buf, size_t len);
14ssize_t m8xx_uart_write(int minor, const char *buf, size_t len);
15int m8xx_uart_setAttributes(int, const struct termios* t);
16
17
18#if 0
19int m8260_smc_set_attributes(int, const struct termios*);
20int m8260_scc_set_attributes(int, const struct termios*);
21void m8260_scc_initialize(int);
22void m8260_smc_initialize(int);
23int m8260_char_poll_read(int);
24int m8260_char_poll_write(int, const char*, int);
25rtems_isr m8260_scc1_console_interrupt_handler(rtems_vector_number);
26rtems_isr m8260_scc2_console_interrupt_handler(rtems_vector_number);
27rtems_isr m8260_scc3_console_interrupt_handler(rtems_vector_number);
28rtems_isr m8260_scc4_console_interrupt_handler(rtems_vector_number);
29rtems_isr m8260_smc1_console_interrupt_handler(rtems_vector_number);
30rtems_isr m8260_smc2_console_interrupt_handler(rtems_vector_number);
31int m8260_buf_poll_read(int, char**);
32int m8260_buf_poll_write(int, char*, int);
33void m8260_console_initialize(void);
36 void*);
39 void*);
40
41
42typedef struct Buf_t_ {
43 struct Buf_t_ *next;
44 volatile char *buf;
45 volatile int len;
46 int pos;
47} Buf_t;
48#endif
49
50#define NUM_PORTS 6
51
52#define SMC1_MINOR 0
53#define SMC2_MINOR 1
54#define SCC1_MINOR 2
55#define SCC2_MINOR 3
56#define SCC3_MINOR 4
57#define SCC4_MINOR 5
58
59
60#endif
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition: io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition: io.h:115
ISR_Handler rtems_isr
This type defines the return type of interrupt service routines.
Definition: intr.h:123
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
rtems_status_code
Definition: status.h:85
Basic IO API.
