RTEMS
6.1
bsps
powerpc
include
libcpu
irq.h
1
2
* irq.h
3
4
* This include file describe the data structure and the functions implemented
5
* by rtems to write interrupt handlers.
6
7
8
* MPC5xx port sponsored by Defence Research and Development Canada - Suffield
9
* Copyright (C) 2004, Real-Time Systems Inc. (querbach@realtime.bc.ca)
10
11
* Derived from libbsp/powerpc/mbx8xx/irq/irq.h:
12
13
* CopyRight (C) 1999 valette@crf.canon.fr
14
15
* This code is heavilly inspired by the public specification of STREAM V2
16
* that can be found at :
17
18
* <http://www.chorus.com/Documentation/index.html> by following
19
* the STREAM API Specification Document link.
20
21
* The license and distribution terms for this file may be
22
* found in the file LICENSE in this distribution or at
23
* http://www.rtems.org/license/LICENSE.
24
25
26
#ifndef _LIBCPU_IRQ_H
27
#define _LIBCPU_IRQ_H
28
29
rtems/irq.h
30
31
#define CPU_ASM_IRQ_VECTOR_BASE 0x0
32
33
#ifndef ASM
34
35
extern
volatile
unsigned
int
ppc_cached_irq_mask;
36
37
38
* Symblolic IRQ names and related definitions.
39
40
41
42
* Base vector for our USIU IRQ handlers.
43
44
#define CPU_USIU_VECTOR_BASE (CPU_ASM_IRQ_VECTOR_BASE)
45
46
* USIU IRQ handler related definitions
47
48
#define CPU_USIU_IRQ_COUNT (16)
/* 16 reserved but in the future... */
49
#define CPU_USIU_IRQ_MIN_OFFSET (0)
50
#define CPU_USIU_IRQ_MAX_OFFSET (CPU_USIU_IRQ_MIN_OFFSET + CPU_USIU_IRQ_COUNT - 1)
51
52
* UIMB IRQ handlers related definitions
53
54
#define CPU_UIMB_IRQ_COUNT (32 - 8)
/* first 8 overlap USIU */
55
#define CPU_UIMB_IRQ_MIN_OFFSET (CPU_USIU_IRQ_COUNT + CPU_USIU_VECTOR_BASE)
56
#define CPU_UIMB_IRQ_MAX_OFFSET (CPU_UIMB_IRQ_MIN_OFFSET + CPU_UIMB_IRQ_COUNT - 1)
57
58
* PowerPc exceptions handled as interrupt where a rtems managed interrupt
59
* handler might be connected
60
61
#define CPU_PROC_IRQ_COUNT (1)
62
#define CPU_PROC_IRQ_MIN_OFFSET (CPU_UIMB_IRQ_MAX_OFFSET + 1)
63
#define CPU_PROC_IRQ_MAX_OFFSET (CPU_PROC_IRQ_MIN_OFFSET + CPU_PROC_IRQ_COUNT - 1)
64
65
* Summary
66
67
#define CPU_IRQ_COUNT (CPU_PROC_IRQ_MAX_OFFSET + 1)
68
#define CPU_MIN_OFFSET (CPU_USIU_IRQ_MIN_OFFSET)
69
#define CPU_MAX_OFFSET (CPU_PROC_IRQ_MAX_OFFSET)
70
71
* USIU IRQ symbolic name definitions.
72
73
#define CPU_USIU_EXT_IRQ_0 (CPU_USIU_IRQ_MIN_OFFSET + 0)
74
#define CPU_USIU_INT_IRQ_0 (CPU_USIU_IRQ_MIN_OFFSET + 1)
75
76
#define CPU_USIU_EXT_IRQ_1 (CPU_USIU_IRQ_MIN_OFFSET + 2)
77
#define CPU_USIU_INT_IRQ_1 (CPU_USIU_IRQ_MIN_OFFSET + 3)
78
79
#define CPU_USIU_EXT_IRQ_2 (CPU_USIU_IRQ_MIN_OFFSET + 4)
80
#define CPU_USIU_INT_IRQ_2 (CPU_USIU_IRQ_MIN_OFFSET + 5)
81
82
#define CPU_USIU_EXT_IRQ_3 (CPU_USIU_IRQ_MIN_OFFSET + 6)
83
#define CPU_USIU_INT_IRQ_3 (CPU_USIU_IRQ_MIN_OFFSET + 7)
84
85
#define CPU_USIU_EXT_IRQ_4 (CPU_USIU_IRQ_MIN_OFFSET + 8)
86
#define CPU_USIU_INT_IRQ_4 (CPU_USIU_IRQ_MIN_OFFSET + 9)
87
88
#define CPU_USIU_EXT_IRQ_5 (CPU_USIU_IRQ_MIN_OFFSET + 10)
89
#define CPU_USIU_INT_IRQ_5 (CPU_USIU_IRQ_MIN_OFFSET + 11)
90
91
#define CPU_USIU_EXT_IRQ_6 (CPU_USIU_IRQ_MIN_OFFSET + 12)
92
#define CPU_USIU_INT_IRQ_6 (CPU_USIU_IRQ_MIN_OFFSET + 13)
93
94
#define CPU_USIU_EXT_IRQ_7 (CPU_USIU_IRQ_MIN_OFFSET + 14)
95
#define CPU_USIU_INT_IRQ_7 (CPU_USIU_IRQ_MIN_OFFSET + 15)
96
97
98
* Symbolic names for UISU interrupt sources.
99
100
#define CPU_PERIODIC_TIMER (CPU_USIU_INT_IRQ_6)
101
#define CPU_UIMB_INTERRUPT (CPU_USIU_INT_IRQ_7)
102
103
104
* UIMB IRQ symbolic name definitions. The first 8 sources are aliases to
105
* the USIU interrupts of the same number, because they are detected in
106
* the USIU pending register rather than the UIMB pending register.
107
108
#define CPU_UIMB_IRQ_0 (CPU_USIU_INT_IRQ_0)
109
#define CPU_UIMB_IRQ_1 (CPU_USIU_INT_IRQ_1)
110
#define CPU_UIMB_IRQ_2 (CPU_USIU_INT_IRQ_2)
111
#define CPU_UIMB_IRQ_3 (CPU_USIU_INT_IRQ_3)
112
#define CPU_UIMB_IRQ_4 (CPU_USIU_INT_IRQ_4)
113
#define CPU_UIMB_IRQ_5 (CPU_USIU_INT_IRQ_5)
114
#define CPU_UIMB_IRQ_6 (CPU_USIU_INT_IRQ_6)
115
#define CPU_UIMB_IRQ_7 (CPU_USIU_INT_IRQ_7)
116
117
#define CPU_UIMB_IRQ_8 (CPU_UIMB_IRQ_MIN_OFFSET+ 0)
118
#define CPU_UIMB_IRQ_9 (CPU_UIMB_IRQ_MIN_OFFSET+ 1)
119
#define CPU_UIMB_IRQ_10 (CPU_UIMB_IRQ_MIN_OFFSET+ 2)
120
#define CPU_UIMB_IRQ_11 (CPU_UIMB_IRQ_MIN_OFFSET+ 3)
121
#define CPU_UIMB_IRQ_12 (CPU_UIMB_IRQ_MIN_OFFSET+ 4)
122
#define CPU_UIMB_IRQ_13 (CPU_UIMB_IRQ_MIN_OFFSET+ 5)
123
#define CPU_UIMB_IRQ_14 (CPU_UIMB_IRQ_MIN_OFFSET+ 6)
124
#define CPU_UIMB_IRQ_15 (CPU_UIMB_IRQ_MIN_OFFSET+ 7)
125
#define CPU_UIMB_IRQ_16 (CPU_UIMB_IRQ_MIN_OFFSET+ 8)
126
#define CPU_UIMB_IRQ_17 (CPU_UIMB_IRQ_MIN_OFFSET+ 9)
127
#define CPU_UIMB_IRQ_18 (CPU_UIMB_IRQ_MIN_OFFSET+ 0)
128
#define CPU_UIMB_IRQ_19 (CPU_UIMB_IRQ_MIN_OFFSET+11)
129
#define CPU_UIMB_IRQ_20 (CPU_UIMB_IRQ_MIN_OFFSET+12)
130
#define CPU_UIMB_IRQ_21 (CPU_UIMB_IRQ_MIN_OFFSET+13)
131
#define CPU_UIMB_IRQ_22 (CPU_UIMB_IRQ_MIN_OFFSET+14)
132
#define CPU_UIMB_IRQ_23 (CPU_UIMB_IRQ_MIN_OFFSET+15)
133
#define CPU_UIMB_IRQ_24 (CPU_UIMB_IRQ_MIN_OFFSET+16)
134
#define CPU_UIMB_IRQ_25 (CPU_UIMB_IRQ_MIN_OFFSET+17)
135
#define CPU_UIMB_IRQ_26 (CPU_UIMB_IRQ_MIN_OFFSET+18)
136
#define CPU_UIMB_IRQ_27 (CPU_UIMB_IRQ_MIN_OFFSET+19)
137
#define CPU_UIMB_IRQ_28 (CPU_UIMB_IRQ_MIN_OFFSET+20)
138
#define CPU_UIMB_IRQ_29 (CPU_UIMB_IRQ_MIN_OFFSET+21)
139
#define CPU_UIMB_IRQ_30 (CPU_UIMB_IRQ_MIN_OFFSET+22)
140
#define CPU_UIMB_IRQ_31 (CPU_UIMB_IRQ_MIN_OFFSET+23)
141
142
143
* Symbolic names for UIMB interrupt sources.
144
145
#define CPU_IRQ_SCI (CPU_UIMB_IRQ_5)
146
147
148
* Processor exceptions handled as rtems IRQ symbolic name definitions.
149
150
#define CPU_DECREMENTER (CPU_PROC_IRQ_MIN_OFFSET)
151
152
153
* Convert an rtems_irq_number constant to an interrupt level
154
* suitable for programming into an I/O device's interrupt level field.
155
156
int
CPU_irq_level_from_symbolic_name(
const
rtems_irq_number name);
157
158
159
| Function Prototypes.
160
161
162
extern
void
CPU_rtems_irq_mng_init(
unsigned
cpuId);
163
164
typedef
struct
MPC5XX_Interrupt_frame
165
uint32_t stacklink;
/* Ensure this is a real frame (also reg1 save) */
166
uint32_t calleeLr;
/* link register used by callees: SVR4/EABI */
167
168
/* This is what is left out of the primary contexts */
169
uint32_t gpr0;
170
uint32_t gpr2;
/* play safe */
171
uint32_t gpr3;
172
uint32_t gpr4;
173
uint32_t gpr5;
174
uint32_t gpr6;
175
uint32_t gpr7;
176
uint32_t gpr8;
177
uint32_t gpr9;
178
uint32_t gpr10;
179
uint32_t gpr11;
180
uint32_t gpr12;
181
uint32_t gpr13;
/* Play safe */
182
uint32_t gpr28;
/* For internal use by the IRQ handler */
183
uint32_t gpr29;
184
uint32_t gpr30;
185
uint32_t gpr31;
186
uint32_t cr;
/* Bits of this are volatile, so no-one may save */
187
uint32_t ctr;
188
uint32_t xer;
189
uint32_t lr;
190
uint32_t pc;
191
uint32_t msr;
192
uint32_t pad[3];
193
194
195
void
C_dispatch_irq_handler(
*frame,
unsigned
int
excNum);
196
197
#endif
198
199
#endif
irq.h
Definition:
irq.h:164
