RTEMS 6.1
irq.h
1/* irq.h
2 *
3 * This include file describe the data structure and the functions implemented
4 * by rtems to write interrupt handlers.
5 *
6 * CopyRight (C) 1999 valette@crf.canon.fr
7 *
8 * This code is heavilly inspired by the public specification of STREAM V2
9 * that can be found at :
10 *
11 * <http://www.chorus.com/Documentation/index.html> by following
12 * the STREAM API Specification Document link.
13 *
14 * The license and distribution terms for this file may be
15 * found in the file LICENSE in this distribution or at
16 * http://www.rtems.org/license/LICENSE.
17 *
18 * Modified by T. Straumann for the beatnik BSP, 2005-2007
19 * Some information may be based on mvme5500/irq/irq.h by K. Feng.
20 */
21
22#ifndef LIBBSP_POWERPC_MOT_PPC_NEW_IRQ_IRQ_H
23#define LIBBSP_POWERPC_MOT_PPC_NEW_IRQ_IRQ_H
24
25#define BSP_SHARED_HANDLER_SUPPORT 1
26#include <rtems/irq.h>
27#include <bsp/vectors.h>
28#include <bsp/irq-default.h>
29
30/* This BSP also passes a pointer to the interrupt frame to the handler.
31 * The PPC ABI guarantees that this will not mess up handlers written
32 * without knowledge of this feature.
33 */
34
35typedef void (*BSP_rtems_irq_hdl)(rtems_irq_hdl_param,BSP_Exception_frame*);
36
37
38/* legal priorities are 0 <= priority <= MAX_PRIO; 0 effectively disables the interrupt */
39#define BSP_IRQ_MAX_PRIO 4
40#define BSP_IRQ_MIN_PRIO 1
41
42/* Note that priorites are only honoured for 'PCI' interrupt numbers.
43 * The discovery pic has no support for hardware priorites; hence they
44 * are handled in software
45 */
46#define BSP_IRQ_DEFAULT_PRIORITY 2
47
48
49#define BSP_PCI_IRQ_LOWEST_OFFSET 0 /* IMPLEMENTATION RELIES ON discovery pic INTERRUPTS HAVING NUMBERS 0..95 */
50#define BSP_IRQ_DEV 1 /* device interface interrupt */
51#define BSP_IRQ_DMA 2 /* DMA addres error interrupt (260) */
52#define BSP_IRQ_CPU 3 /* CPU interface interrupt */
53#define BSP_IRQ_IDMA0_1 4 /* IDMA ch. 0..1 complete interrupt (260) */
54#define BSP_IRQ_IDMA2_3 5 /* IDMA ch. 2..3 complete interrupt (260) */
55#define BSP_IRQ_IDMA4_5 6 /* IDMA ch. 4..5 complete interrupt (260) */
56#define BSP_IRQ_IDMA6_7 7 /* IDMA ch. 6..7 complete interrupt (260) */
57#define BSP_IRQ_TIME0_1 8 /* Timer 0..1 interrupt; Timer 0 on 64360 */
58#define BSP_IRQ_TIME2_3 9 /* Timer 2..3 interrupt; Timer 1 on 64360 */
59#define BSP_IRQ_TIME4_5 10 /* Timer 4..5 interrupt; Timer 2 on 64360 */
60#define BSP_IRQ_TIME6_7 11 /* Timer 6..7 interrupt; Timer 3 on 64360 */
61#define BSP_IRQ_PCI0_0 12 /* PCI 0 interrupt 0 summary (PCI 0 interrupt summary on 64360) */
62#define BSP_IRQ_PCI0_1 13 /* PCI 0 interrupt 1 summary (SRAM PAR ERROR on 64360) */
63#define BSP_IRQ_PCI0_2 14 /* PCI 0 interrupt 2 summary */
64#define BSP_IRQ_PCI0_3 15 /* PCI 0 interrupt 3 summary */
65#define BSP_IRQ_PCI1_0 16 /* PCI 1 interrupt 0 summary (PCI 1 interrupt summary on 64360) */
66#define BSP_IRQ_ECC 17 /* ECC error interrupt */
67#define BSP_IRQ_PCI1_1 18 /* PCI 1 interrupt 1 summary */
68#define BSP_IRQ_PCI1_2 19 /* PCI 1 interrupt 2 summary */
69#define BSP_IRQ_PCI1_3 20 /* PCI 1 interrupt 3 summary */
70#define BSP_IRQ_PCI0OUT_LO 21 /* PCI 0 outbound interrupt summary */
71#define BSP_IRQ_PCI0OUT_HI 22 /* PCI 0 outbound interrupt summary */
72#define BSP_IRQ_PCI1OUT_LO 23 /* PCI 1 outbound interrupt summary */
73#define BSP_IRQ_PCI1OUT_HI 24 /* PCI 1 outbound interrupt summary */
74#define BSP_IRQ_PCI0IN_LO 26 /* PCI 0 inbound interrupt summary */
75#define BSP_IRQ_PCI0IN_HI 27 /* PCI 0 inbound interrupt summary */
76#define BSP_IRQ_PCI1IN_LO 28 /* PCI 1 inbound interrupt summary */
77#define BSP_IRQ_PCI1IN_HI 29 /* PCI 1 inbound interrupt summary */
78#define BSP_IRQ_ETH0 (32+0) /* Ethernet controller 0 interrupt */
79#define BSP_IRQ_ETH1 (32+1) /* Ethernet controller 1 interrupt */
80#define BSP_IRQ_ETH2 (32+2) /* Ethernet controller 2 interrupt */
81#define BSP_IRQ_SDMA (32+4) /* SDMA interrupt */
82#define BSP_IRQ_I2C (32+5) /* I2C interrupt */
83#define BSP_IRQ_BRG (32+7) /* Baud Rate Generator interrupt */
84#define BSP_IRQ_MPSC0 (32+8) /* MPSC 0 interrupt */
85#define BSP_IRQ_MPSC1 (32+10) /* MPSC 1 interrupt */
86#define BSP_IRQ_COMM (32+11) /* Comm unit interrupt */
87#define BSP_IRQ_GPP7_0 (32+24) /* GPP[7..0] interrupt summary */
88#define BSP_IRQ_GPP15_8 (32+25) /* GPP[15..8] interrupt summary */
89#define BSP_IRQ_GPP23_16 (32+26) /* GPP[23..16] interrupt summary */
90#define BSP_IRQ_GPP31_24 (32+27) /* GPP[31..24] interrupt summary */
91#define BSP_IRQ_GPP_0 64
92
93#define BSP_PCI_IRQ_NUMBER (64+32)
94#define BSP_PCI_IRQ_MAX_OFFSET (BSP_PCI_IRQ_LOWEST_OFFSET + BSP_PCI_IRQ_NUMBER - 1)
95
96#define BSP_PROCESSOR_IRQ_NUMBER 1
97#define BSP_PROCESSOR_IRQ_LOWEST_OFFSET (BSP_PCI_IRQ_MAX_OFFSET+1)
98#define BSP_PROCESSOR_IRQ_MAX_OFFSET (BSP_PROCESSOR_IRQ_LOWEST_OFFSET + BSP_PROCESSOR_IRQ_NUMBER - 1)
99
100/* summary */
101
102#define BSP_IRQ_NUMBER (BSP_PCI_IRQ_NUMBER + BSP_PROCESSOR_IRQ_NUMBER)
103#define BSP_LOWEST_OFFSET 0
104#define BSP_MAX_OFFSET (BSP_LOWEST_OFFSET + BSP_IRQ_NUMBER - 1)
105#define BSP_DECREMENTER BSP_PROCESSOR_IRQ_LOWEST_OFFSET
106
107#define BSP_UART_COM1_IRQ BSP_IRQ_GPP_0
108#define BSP_UART_COM2_IRQ BSP_IRQ_GPP_0
109
110#ifndef ASM
111
112#ifdef __cplusplus
113extern "C" {
114#endif
115
116
117#include <bsp/irq_supp.h>
118
119int BSP_irq_is_enabled_at_pic(rtems_irq_number irq);
120
121/* set priority of an interrupt; must not be called from ISR level */
122int BSP_irq_set_priority(rtems_irq_number irq, rtems_irq_prio pri);
123
124/* Not for public use */
125void BSP_rtems_irq_mng_init(unsigned cpuId);
126
127#ifdef __cplusplus
128}
129#endif
130
131
132#endif
133
134#endif
PowerPC Exceptions API.
The set of registers that specifies the complete processor state.
Definition: cpu.h:446
