RTEMS 6.1
bsp.h
2
11/*
12 * COPYRIGHT (c) 1989-2012.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef LIBBSP_MIPS_MALTA_BSP_H
38#define LIBBSP_MIPS_MALTA_BSP_H
39
50#ifndef ASM
51
52#include <bspopts.h>
54
55#include <rtems.h>
56
57#ifdef __cplusplus
58extern "C" {
59#endif
60
61#define BSP_FEATURE_IRQ_EXTENSION
62#define BSP_SHARED_HANDLER_SUPPORT 1
63
64#define REVISION_REGISTER_ADDRESS 0x1fc00010
65#define PRORV_MASK 0x0000000f /* 4 bit Product Revision */
66#define PROID_MASK 0x000000f0 /* 4 bit Product ID */
67#define CORRV_MASK 0x00000300 /* 2 bit Core Board Revision */
68#define CORID_MASK 0x0000fc00 /* 6 bit Core Board ID */
69#define FPGRV_MASK 0x00ff0000 /* 8 bit CBUS FPGA Revision */
70#define BSP_8259_BASE_ADDRESS (0x18000000UL | 0xa0000000UL)
71#define BSP_PCI_BASE_ADDRESS (0x1be00000UL | 0xa0000000UL)
72#define BSP_NIC_IO_BASE (0x10000000UL | 0xa0000000UL)
73#define PCI0_IO_BASE (0x18000000UL | 0xa0000000UL)
74#define BSP_NIC_MEM_BASE (0x00000000UL | 0xa0000000UL)
75
76/* functions */
77#define WRITE_PROTECTED_UINT8( _addr, _value ) \
78 do { \
79 volatile uint8_t *_ptr = _addr | 0x80000000; \
80 *_ptr = _value; \
81 }
82#define WRITE_PROTECTED_UINT16( _addr, _value ) \
83 do { \
84 volatile uint16_t *_ptr = _addr | 0x80000000; \
85 *_ptr = _value; \
86 }
87#define WRITE_PROTECTED_UINT32( _addr, _value ) \
88 do { \
89 volatile uint32_t *_ptr = _addr | 0x80000000; \
90 *_ptr = _value; \
91 }
92#define READ_PROTECTED_UINT8( _addr, _value ) \
93 do { \
94 volatile uint8_t *_ptr = _addr | 0x80000000; \
95 _value = *_ptr; \
96 }
97#define READ_PROTECTED_UINT16( _addr, _value ) \
98 do { \
99 volatile uint16_t *_ptr = _addr | 0x80000000; \
100 _value = *_ptr; \
101 }
102#define READ_PROTECTED_UINT32( _addr, _value ) \
103 do { \
104 volatile uint32_t *_ptr = _addr | 0x80000000; \
105 _value = *_ptr; \
106 }
107
108#define READ_UINT8( _register_, _value_ ) \
109 ((_value_) = *((volatile unsigned char *)(_register_)))
110
111#define WRITE_UINT8( _register_, _value_ ) \
112 (*((volatile unsigned char *)(_register_)) = (_value_))
113
114#define READ_UINT16( _register_, _value_ ) \
115 ((_value_) = *((volatile unsigned short *)(_register_)))
116
117#define WRITE_UINT16( _register_, _value_ ) \
118 (*((volatile unsigned short *)(_register_)) = (_value_))
119
120void simple_out_32(uint32_t base, uint32_t addr, uint32_t val);
121void simple_out_le32(uint32_t base, uint32_t addr, uint32_t val);
122uint8_t simple_in_8( uint32_t base, uint32_t addr );
123void simple_out_8( uint32_t base, uint32_t addr, uint8_t val );
124int16_t simple_in_le16( uint32_t base, uint32_t addr );
125int16_t simple_in_16( uint32_t base, uint32_t addr );
126uint32_t simple_in_le32( uint32_t base, uint32_t addr );
127uint32_t simple_in_32( uint32_t base, uint32_t addr );
128void simple_out_le16( uint32_t base, uint32_t addr, uint16_t val );
129void simple_out_16( uint32_t base, uint32_t addr, uint16_t val );
130
131/*
132 * Prototypes for methods called from .S for dependency tracking
133 */
134void init_tlb(void);
135void resettlb(int i);
136
137#ifdef __cplusplus
138}
139#endif
140
141#endif /* !ASM */
142
145#endif
This header file provides the default definition of BSP_INITIAL_EXTENSION.
