RTEMS
6.1
bsps
mips
jmr3904
include
bsp.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
* COPYRIGHT (c) 1989-2012.
13
* On-Line Applications Research Corporation (OAR).
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef LIBBSP_MIPS_JMR3904_BSP_H
38
#define LIBBSP_MIPS_JMR3904_BSP_H
39
50
#include <bspopts.h>
51
bsp/default-initial-extension.h
52
53
rtems.h
54
libcpu/tx3904.h
55
56
#ifdef __cplusplus
57
extern
"C"
58
#endif
59
60
#define BSP_FEATURE_IRQ_EXTENSION
61
#define BSP_SHARED_HANDLER_SUPPORT 1
62
63
#ifdef __cplusplus
64
65
#endif
66
69
#endif
This header file provides the default definition of BSP_INITIAL_EXTENSION.
rtems.h
tx3904.h
