RTEMS 6.1
irq.h
2
11/*
12 * COPYRIGHT (c) 1989-2012.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef LIBBSP_MIPS_JMR3904_IRQ_H
38#define LIBBSP_MIPS_JMR3904_IRQ_H
39
40#ifndef ASM
41 #include <rtems.h>
42 #include <rtems/irq.h>
43 #include <rtems/irq-extension.h>
44 #include <rtems/score/mips.h>
45#endif
46
53/*
54 * Interrupt Vector Numbers
55 *
56 * NOTE: Numbers 0-15 directly map to levels on the IRC.
57 * Number 16 is "1xxxx" per p. 164 of the TX3904 manual.
58 */
59
60 #define TX3904_IRQ_INT1 MIPS_INTERRUPT_BASE+0
61 #define TX3904_IRQ_INT2 MIPS_INTERRUPT_BASE+1
62 #define TX3904_IRQ_INT3 MIPS_INTERRUPT_BASE+2
63 #define TX3904_IRQ_INT4 MIPS_INTERRUPT_BASE+3
64 #define TX3904_IRQ_INT5 MIPS_INTERRUPT_BASE+4
65 #define TX3904_IRQ_INT6 MIPS_INTERRUPT_BASE+5
66 #define TX3904_IRQ_INT7 MIPS_INTERRUPT_BASE+6
67 #define TX3904_IRQ_DMAC3 MIPS_INTERRUPT_BASE+7
68 #define TX3904_IRQ_DMAC2 MIPS_INTERRUPT_BASE+8
69 #define TX3904_IRQ_DMAC1 MIPS_INTERRUPT_BASE+9
70 #define TX3904_IRQ_DMAC0 MIPS_INTERRUPT_BASE+10
71 #define TX3904_IRQ_SIO0 MIPS_INTERRUPT_BASE+11
72 #define TX3904_IRQ_SIO1 MIPS_INTERRUPT_BASE+12
73 #define TX3904_IRQ_TMR0 MIPS_INTERRUPT_BASE+13
74 #define TX3904_IRQ_TMR1 MIPS_INTERRUPT_BASE+14
75 #define TX3904_IRQ_TMR2 MIPS_INTERRUPT_BASE+15
76 #define TX3904_IRQ_INT0 MIPS_INTERRUPT_BASE+16
77 #define TX3904_IRQ_SOFTWARE_1 MIPS_INTERRUPT_BASE+17
78 #define TX3904_IRQ_SOFTWARE_2 MIPS_INTERRUPT_BASE+18
79 #define TX3904_MAXIMUM_VECTORS MIPS_INTERRUPT_BASE+19
80
81#define BSP_INTERRUPT_VECTOR_COUNT (TX3904_MAXIMUM_VECTORS + 1)
82
85#endif /* LIBBSP_MIPS_JMR3904_IRQ_H */
This header file is provided for backward compatiblility.
Information to build RTEMS for a "no cpu" while in protected mode.
