RTEMS 6.1
bsp.h
2
11/*
12 * COPYRIGHT (c) 1989-2012.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef LIBBSP_MIPS_CSB350_BSP_H
38#define LIBBSP_MIPS_CSB350_BSP_H
39
50#include <bspopts.h>
52
53#include <rtems.h>
54#include <libcpu/au1x00.h>
55
56#ifdef __cplusplus
57extern "C" {
58#endif
59
60#define BSP_FEATURE_IRQ_EXTENSION
61#define BSP_SHARED_HANDLER_SUPPORT 1
62
63/*
64 * Network driver configuration
65 */
66struct rtems_bsdnet_ifconfig;
67
68int rtems_au1x00_emac_attach(struct rtems_bsdnet_ifconfig *config,
69 int attaching);
70#define RTEMS_BSP_NETWORK_DRIVER_NAME "eth0"
71#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_au1x00_emac_attach
72
73#ifdef __cplusplus
74}
75#endif
76
79#endif
This header file provides the default definition of BSP_INITIAL_EXTENSION.
Definition: deflate.c:114
