RTEMS 6.1
timer.h
2
11/*
12 * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_MICROBLAZE_FPGA_TIMER_H
37#define LIBBSP_MICROBLAZE_FPGA_TIMER_H
38
39#include <bspopts.h>
40
41#include <bsp/utility.h>
42
43#ifdef __cplusplus
44extern "C" {
45#endif /* __cplusplus */
46
47typedef struct {
48#define MICROBLAZE_TIMER_TCSR0_T0INT BSP_BIT32(8)
49#define MICROBLAZE_TIMER_TCSR0_ENT0 BSP_BIT32(7)
50#define MICROBLAZE_TIMER_TCSR0_ENIT0 BSP_BIT32(6)
51#define MICROBLAZE_TIMER_TCSR0_LOAD0 BSP_BIT32(5)
52#define MICROBLAZE_TIMER_TCSR0_ARHT0 BSP_BIT32(4)
53#define MICROBLAZE_TIMER_TCSR0_GENT0 BSP_BIT32(2)
54#define MICROBLAZE_TIMER_TCSR0_UDT0 BSP_BIT32(1)
55 /* Control/Status register */
56 uint32_t tcsr0;
57 /* Load register */
58 uint32_t tlr0;
59 /* Timer counter register */
60 uint32_t tcr0;
62
63#ifdef __cplusplus
64}
65#endif /* __cplusplus */
66
67#endif /* LIBBSP_MICROBLAZE_FPGA_TIMER_H */
This header file provides utility macros for BSPs.
Definition: timer.h:47
