RTEMS 6.1
bsp.h
2
11/*
12 * Board Support Package for `Generic' Motorola MC68340
13 *
14 * Based on the `gen68360' board support package, and covered by the
15 * original distribution terms.
16 */
17
18/* bsp.h
19 *
20 * COPYRIGHT (c) 1989-1999.
21 * On-Line Applications Research Corporation (OAR).
22 *
23 * Redistribution and use in source and binary forms, with or without
24 * modification, are permitted provided that the following conditions
25 * are met:
26 * 1. Redistributions of source code must retain the above copyright
27 * notice, this list of conditions and the following disclaimer.
28 * 2. Redistributions in binary form must reproduce the above copyright
29 * notice, this list of conditions and the following disclaimer in the
30 * documentation and/or other materials provided with the distribution.
31 *
32 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
33 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
34 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
35 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
36 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
37 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
38 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
39 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
40 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
41 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
42 * POSSIBILITY OF SUCH DAMAGE.
43 */
44
45#ifndef LIBBSP_M68K_GEN68340_BSP_H
46#define LIBBSP_M68K_GEN68340_BSP_H
47
58#ifndef ASM
59
60#include <bspopts.h>
62
63#include <rtems.h>
64
65#ifdef __cplusplus
66extern "C" {
67#endif
68
69/* Constants */
70
71/* Structures */
72
73extern rtems_isr_entry M68Kvec[]; /* vector table address */
74
75/* functions */
76
77rtems_isr_entry set_vector(
78 rtems_isr_entry handler,
80 int type
81);
82
83/*
84 * Methods used across files inside the BSP
85 */
86int dbug_in_char( int minor );
87void dbug_out_char( int minor, int ch );
88int dbug_char_present( int minor );
89void _dbug_dumpanic(void);
90
91/*
92 * Only called from .S but prototyped here to capture the dependecy.
93 */
94void _Init68340 (void);
95
96#ifdef __cplusplus
97}
98#endif
99
100#endif /* !ASM */
101
104#endif
This header file provides the default definition of BSP_INITIAL_EXTENSION.
ISR_Handler_entry rtems_isr_entry
Interrupt service routines installed by rtems_interrupt_catch() shall have this type.
Definition: intr.h:134
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
