RTEMS 6.1
clock.h
2
9/*
10 * This file contains definitions for LatticeMico32 Timer (Clock)
11 *
12 * COPYRIGHT (c) 1989-1999.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 *
36 * Jukka Pietarinen <jukka.pietarinen@mrf.fi>, 2008,
37 * Micro-Research Finland Oy
38 */
39
47#ifndef _BSPCLOCK_H
48#define _BSPCLOCK_H
49
52#define LM32_CLOCK_SR (0x0000)
53#define LM32_CLOCK_SR_TO (0x0001)
54#define LM32_CLOCK_SR_RUN (0x0002)
55
58#define LM32_CLOCK_CR (0x0004)
59#define LM32_CLOCK_CR_ITO (0x0001)
60#define LM32_CLOCK_CR_CONT (0x0002)
61#define LM32_CLOCK_CR_START (0x0004)
62#define LM32_CLOCK_CR_STOP (0x0008)
63
66#define LM32_CLOCK_PERIOD (0x0008)
67
70#define LM32_CLOCK_SNAPSHOT (0x000C)
71
72#endif /* _BSPCLOCK_H */
73
