RTEMS 6.1
bsp.h
2
11/*
12 * COPYRIGHT (c) 1989-1999.
13 * On-Line Applications Research Corporation (OAR).
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 *
36 * Jukka Pietarinen <jukka.pietarinen@mrf.fi>, 2008,
37 * Micro-Research Finland Oy
38 */
39
40#ifndef LIBBSP_LM32_LM32_EVR_BSP_H
41#define LIBBSP_LM32_LM32_EVR_BSP_H
42
52#include <stdint.h>
53#include <bspopts.h>
55
56#include <rtems.h>
57
58#ifdef __cplusplus
59extern "C" {
60#endif
61
62/*
63 * lm32 requires certain aligment of mbuf because unaligned uint32_t
64 * accesses are not handled properly.
65 */
66
67#define CPU_U32_FIX
68
69#if defined(RTEMS_NETWORKING)
70struct rtems_bsdnet_ifconfig;
71
72extern int rtems_tsmac_driver_attach(struct rtems_bsdnet_ifconfig *config,
73 int attaching);
74
75#define RTEMS_BSP_NETWORK_DRIVER_NAME "TSMAC0"
76#define RTEMS_BSP_NETWORK_DRIVER_ATTACH rtems_tsmac_driver_attach
77
78 /*
79 * Due to a hardware design error (RJ45 connector with 10baseT magnetics)
80 * we are forced to use 10baseT mode.
81 */
82
83#define TSMAC_FORCE_10BASET
84#endif
85
86/* functions */
87rtems_isr_entry set_vector( /* returns old vector */
88 rtems_isr_entry handler, /* isr routine */
89 rtems_vector_number vector, /* vector number */
90 int type /* RTEMS or RAW intr */
91);
92
93/*
94 * Prototypes for BSP methods that cross file boundaries
95 */
96void BSP_uart_polled_write(char ch);
97int BSP_uart_polled_read( void );
98char BSP_uart_is_character_ready(char *ch);
99
100#ifdef __cplusplus
101}
102#endif
103
106#endif
107/* end of include file */
This header file provides the default definition of BSP_INITIAL_EXTENSION.
ISR_Handler_entry rtems_isr_entry
Interrupt service routines installed by rtems_interrupt_catch() shall have this type.
Definition: intr.h:134
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
Definition: deflate.c:114
