RTEMS 6.1
mpci.h
2
3/* mpci.h
4 *
5 * This include file contains all the renaming necessary to
6 * have an application use the Shared Memory Driver as its
7 * sole mechanism for MPCI.
8 *
9 * COPYRIGHT (c) 1989-1999.
10 * On-Line Applications Research Corporation (OAR).
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef __SHM_MPCI_h
35#define __SHM_MPCI_h
36
37#ifdef __cplusplus
38extern "C" {
39#endif
40
41#include <shm_driver.h>
42
43#define MPCI_Initialization( _configuration ) \
44 Shm_Initialization( _configuration )
45
46#define MPCI_Get_packet( _the_packet ) \
47 Shm_Get_packet( _the_packet )
48
49#define MPCI_Return_packet( _the_packet ) \
50 Shm_Return_packet( _the_packet )
51
52#define MPCI_Receive_packet( _the_packet ) \
53 Shm_Receive_packet( _the_packet )
54
55#define MPCI_Send_packet( _destination, _the_packet ) \
56 Shm_Send_packet( _destination, _the_packet )
57
58/* Unnecessary... mapped in shm_driver.h
59#define MPCI_Fatal( _the_error ) \
60 Shm_Fatal( _the_error )
61*/
62
63#define MPCI_Enable_statistics()
64
65#define MPCI_Print_statistics() \
66 Shm_Print_statistics()
67
68/* no need to rename the MPCI_Table either */
69
70#ifdef __cplusplus
71}
72#endif
73
74#endif
75/* end of include file */
