RTEMS 6.1
rtc.h
2
3/*
4 * This file contains the Real-Time Clock definitions.
5 *
6 * COPYRIGHT (c) 1989-1999.
7 * On-Line Applications Research Corporation (OAR).
8 *
9 * Redistribution and use in source and binary forms, with or without
10 * modification, are permitted provided that the following conditions
11 * are met:
12 * 1. Redistributions of source code must retain the above copyright
13 * notice, this list of conditions and the following disclaimer.
14 * 2. Redistributions in binary form must reproduce the above copyright
15 * notice, this list of conditions and the following disclaimer in the
16 * documentation and/or other materials provided with the distribution.
17 *
18 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
19 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
20 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
21 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
22 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
23 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
24 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
25 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
26 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
27 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
28 * POSSIBILITY OF SUCH DAMAGE.
29 */
30
31#ifndef __LIBCHIP_RTC_h
32#define __LIBCHIP_RTC_h
33
34#include <stdbool.h>
35#include <stdint.h>
36
37#include <rtems.h>
38
39/*
40 * Types for get and set register routines
41 */
42
43typedef uint32_t (*getRegister_f)(uintptr_t port, uint8_t reg);
44typedef void (*setRegister_f)(uintptr_t port, uint8_t reg, uint32_t value);
45
46typedef struct _rtc_fns {
47 void (*deviceInitialize)(int minor);
48 int (*deviceGetTime)(int minor, rtems_time_of_day *time);
49 int (*deviceSetTime)(int minor, const rtems_time_of_day *time);
50} rtc_fns;
51
52typedef enum {
53 RTC_M48T08, /* SGS-Thomsom M48T08 or M48T18 */
54 RTC_ICM7170, /* Harris ICM-7170 */
55 RTC_CUSTOM, /* BSP specific driver */
56 RTC_MC146818A /* Motorola MC146818A */
57} rtc_devs;
58
59/*
60 * Each field is interpreted thus:
61 *
62 * sDeviceName This is the name of the device.
63 *
64 * deviceType This indicates the chip type.
65 *
66 * pDeviceFns This is a pointer to the set of driver routines to use.
67 *
68 * pDeviceParams This contains either device specific data or a pointer to a
69 * device specific information table.
70 *
71 * ulCtrlPort1 This is the primary control port number for the device.
72 *
73 * ulDataPort This is the port number for the data port of the device
74 *
75 * getRegister This is the routine used to read register values.
76 *
77 * setRegister This is the routine used to write register values.
78 */
79
80typedef struct _rtc_tbl {
81 const char *sDeviceName;
82 rtc_devs deviceType;
83 const rtc_fns *pDeviceFns;
84 bool (*deviceProbe)(int minor);
85 void *pDeviceParams;
86 uintptr_t ulCtrlPort1;
87 uintptr_t ulDataPort;
88 getRegister_f getRegister;
89 setRegister_f setRegister;
90} rtc_tbl;
91
92extern rtc_tbl RTC_Table[];
93extern size_t RTC_Count;
94
95
96extern bool rtc_probe( int minor );
97
98#endif
99/* end of include file */
Definition: rtc.h:46
Definition: rtc.h:80
This type represents Classic API calendar times.
Definition: types.h:266
