RTEMS 6.1
bsp.h
1
9/* bsp.h
10 *
11 * This include file contains all board IO definitions for bf537Stamp.
12 *
13 * Copyright (c) 2006 by Atos Automacao Industrial Ltda.
14 * written by Alain Schaefer <alain.schaefer@easc.ch>
15 * and Antonio Giovanini <antonio@atos.com.br>
16 *
17 * The license and distribution terms for this file may be
18 * found in the file LICENSE in this distribution or at
19 * http://www.rtems.org/license/LICENSE.
20 */
21
22
23#ifndef LIBBSP_BFIN_BF537STAMP_BSP_H
24#define LIBBSP_BFIN_BF537STAMP_BSP_H
25
36#ifndef ASM
37
38#include <bspopts.h>
40
41#include <rtems.h>
42
43#include <libcpu/bf537.h>
44#include <libcpu/memoryRegs.h>
45
46#ifdef __cplusplus
47extern "C" {
48#endif
49
50/* configure data cache to use 16K of each SRAM bank when enabled */
51#define BSP_DATA_CACHE_CONFIG (3 << DMEM_CONTROL_DMC_SHIFT)
52
53
54/*
55 * PLL and clock setup values:
56 */
57
58/*
59 * PLL configuration for bf533Stamp
60 *
61 * XTL = 27 MHz
62 * CLKIN = 13 MHz
63 * VCO = 391 MHz
64 * CCLK = 391 MHz
65 * SCLK = 130 MHz
66 */
67
68#define PLL_CSEL 0x0000 /* CCLK = VCO */
69#define PLL_SSEL 0x0003 /* SCLK = CCLK/3 */
70#define PLL_MSEL 0x3A00 /* VCO = 29xCLKIN */
71#define PLL_DF 0x0001 /* CLKIN = XTL/2 */
72
73#define CCLK 500000000 /* CORE CLOCK */
74#define SCLK 100000000 /* SYSTEM CLOCK */
75
76#define CONSOLE_FORCE_BAUD 57600
77
78/*
79 * Blackfin environment memory map
80 */
81#define L1_DATA_SRAM_A 0xff800000L
82
83#define FIFOLENGTH 0x100
84
85/*
86 * Simple spin delay in microsecond units for device drivers.
87 * This is very dependent on the clock speed of the target.
88 */
89
90#define rtems_bsp_delay( microseconds ) \
91 { \
92 }
93
94/* Constants */
95
96#define RAM_START 0
97#define RAM_END 0x4000000
98
99/* functions */
100
101/*
102 * Helper Function to use the EzKits LEDS.
103 * Can be used by the Application.
104 */
105void setLED(uint8_t value);
106
107/*
108 * Helper Function to use the EzKits LEDS
109 */
110uint8_t getLEDs(void);
111void setLEDs(uint8_t value);
112uint8_t getButtons(void);
113
114rtems_isr_entry set_vector( /* returns old vector */
115 rtems_isr_entry handler, /* isr routine */
116 rtems_vector_number vector, /* vector number */
117 int type /* RTEMS or RAW intr */
118);
119
120/*
121 * Internal BSP methods that are used across file boundaries
122 */
123void Init_RTC(void);
124
125/*
126 * Network driver configuration
127 */
128struct rtems_bsdnet_ifconfig;
129extern int bf537Stamp_network_driver_attach(struct rtems_bsdnet_ifconfig *, int);
130
131#define RTEMS_BSP_NETWORK_DRIVER_NAME "eth1"
132#define RTEMS_BSP_NETWORK_DRIVER_ATTACH bf537Stamp_network_driver_attach
133
134#ifdef __cplusplus
135}
136#endif
137
138#endif /* !ASM */
139
140/* @} */
141
142#endif
This header file provides the default definition of BSP_INITIAL_EXTENSION.
ISR_Handler_entry rtems_isr_entry
Interrupt service routines installed by rtems_interrupt_catch() shall have this type.
Definition: intr.h:134
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition: intr.h:102
