RTEMS 6.1
irq.h
1
7/*
8 * SPDX-License-Identifier: BSD-2-Clause
9 *
10 * Copyright (C) 2013 embedded brains GmbH & Co. KG
11 *
12 * Copyright (C) 2019 DornerWorks
13 *
14 * Written by Jeff Kubascik <jeff.kubascik@dornerworks.com>
15 * and Josh Whitehead <josh.whitehead@dornerworks.com>
16 *
17 * Redistribution and use in source and binary forms, with or without
18 * modification, are permitted provided that the following conditions
19 * are met:
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 * 2. Redistributions in binary form must reproduce the above copyright
23 * notice, this list of conditions and the following disclaimer in the
24 * documentation and/or other materials provided with the distribution.
25 *
26 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
27 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
28 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
29 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
30 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
31 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
32 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
33 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
34 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
35 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
36 * POSSIBILITY OF SUCH DAMAGE.
37 */
38
39#ifndef LIBBSP_ARM_XILINX_ZYNQMP_IRQ_H
40#define LIBBSP_ARM_XILINX_ZYNQMP_IRQ_H
41
42#ifndef ASM
43
44#include <rtems/irq.h>
45#include <rtems/irq-extension.h>
46
47#include <dev/irq/arm-gic-irq.h>
48
49#ifdef __cplusplus
50extern "C" {
51#endif /* __cplusplus */
52
60/* PPIs */
61#define ZYNQMP_IRQ_HYP_TIMER 26
62#define ZYNQMP_IRQ_VIRT_TIMER 27
63#define ZYNQMP_IRQ_S_PHYS_TIMER 29
64#define ZYNQMP_IRQ_NS_PHYS_TIMER 30
65
66/* SPIs */
67#define ZYNQMP_IRQ_UART_0 53
68#define ZYNQMP_IRQ_UART_1 54
69
70#define BSP_INTERRUPT_VECTOR_COUNT 188
71
74#ifdef __cplusplus
75}
76#endif /* __cplusplus */
77
78#endif /* ASM */
79
80#endif /* LIBBSP_ARM_XILINX_ZYNQMP_IRQ_H */
This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) support.
This header file is provided for backward compatiblility.
