RTEMS 6.1
irq.h
2
11/*
12 * Copyright (C) 2024 embedded brains GmbH & Co. KG
13 * Copyright (C) 2023 Reflex Aerospace GmbH
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef LIBBSP_ARM_XILINX_ZYNQMP_RPU_IRQ_H
38#define LIBBSP_ARM_XILINX_ZYNQMP_RPU_IRQ_H
39
40#ifndef ASM
41
42#include <rtems.h>
43
44#include <bspopts.h>
45#include <dev/irq/arm-gic-irq.h>
47
48#ifdef __cplusplus
49extern "C" {
50#endif /* __cplusplus */
51
52#ifndef ZYNQMP_RPU_LOCK_STEP_MODE
53#define BSP_IRQ_HAVE_GET_SET_AFFINITY
54#endif
55
56#define BSP_INTERRUPT_VECTOR_COUNT 188
57
60#ifdef __cplusplus
61}
62#endif /* __cplusplus */
63
64#endif /* ASM */
65
66#endif /* LIBBSP_ARM_XILINX_ZYNQMP_RPU_IRQ_H */
This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) support.
Xilinx Zynq Ultrascale+ MPSoC Peripheral memory map.
