RTEMS 6.1
memory.h
2
3/*
4 * Copyright (C) 2020 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SMEMORYL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef LIBBSP_ARM_STM32H7_STM32H7_MEMORY_H
29#define LIBBSP_ARM_STM32H7_STM32H7_MEMORY_H
30
31#ifdef __cplusplus
32extern "C" {
33#endif
34
35extern char stm32h7_memory_null_begin[];
36extern char stm32h7_memory_null_end[];
37extern char stm32h7_memory_null_size[];
38
39extern char stm32h7_memory_itcm_begin[];
40extern char stm32h7_memory_itcm_end[];
41extern char stm32h7_memory_itcm_size[];
42
43extern char stm32h7_memory_flash_begin[];
44extern char stm32h7_memory_flash_end[];
45extern char stm32h7_memory_flash_size[];
46
47extern char stm32h7_memory_dtcm_begin[];
48extern char stm32h7_memory_dtcm_end[];
49extern char stm32h7_memory_dtcm_size[];
50
51extern char stm32h7_memory_sram_axi_begin[];
52extern char stm32h7_memory_sram_axi_end[];
53extern char stm32h7_memory_sram_axi_size[];
54
55extern char stm32h7_memory_sram_1_begin[];
56extern char stm32h7_memory_sram_1_end[];
57extern char stm32h7_memory_sram_1_size[];
58
59extern char stm32h7_memory_sram_2_begin[];
60extern char stm32h7_memory_sram_2_end[];
61extern char stm32h7_memory_sram_2_size[];
62
63extern char stm32h7_memory_sram_3_begin[];
64extern char stm32h7_memory_sram_3_end[];
65extern char stm32h7_memory_sram_3_size[];
66
67extern char stm32h7_memory_sram_4_begin[];
68extern char stm32h7_memory_sram_4_end[];
69extern char stm32h7_memory_sram_4_size[];
70
71extern char stm32h7_memory_sram_backup_begin[];
72extern char stm32h7_memory_sram_backup_end[];
73extern char stm32h7_memory_sram_backup_size[];
74
75extern char stm32h7_memory_peripheral_begin[];
76extern char stm32h7_memory_peripheral_end[];
77extern char stm32h7_memory_peripheral_size[];
78
79extern char stm32h7_memory_nor_begin[];
80extern char stm32h7_memory_nor_end[];
81extern char stm32h7_memory_nor_size[];
82
83extern char stm32h7_memory_sdram_1_begin[];
84extern char stm32h7_memory_sdram_1_end[];
85extern char stm32h7_memory_sdram_1_size[];
86
87extern char stm32h7_memory_nand_begin[];
88extern char stm32h7_memory_nand_end[];
89extern char stm32h7_memory_nand_size[];
90
91extern char stm32h7_memory_quadspi_begin[];
92extern char stm32h7_memory_quadspi_end[];
93extern char stm32h7_memory_quadspi_size[];
94
95extern char stm32h7_memory_sdram_2_begin[];
96extern char stm32h7_memory_sdram_2_end[];
97extern char stm32h7_memory_sdram_2_size[];
98
99#ifdef __cplusplus
100}
101#endif
102
103#endif /* LIBBSP_ARM_STM32H7_STM32H7_MEMORY_H */
