RTEMS 6.1
bsp.h
2
11/*
12 * Copyright (c) 2013 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_REALVIEW_PBX_A9_BSP_H
37#define LIBBSP_ARM_REALVIEW_PBX_A9_BSP_H
38
48#include <bspopts.h>
49
50#define BSP_FEATURE_IRQ_EXTENSION
51
52#define BSP_HAS_FRAME_BUFFER 1
53
54#ifndef ASM
55
56#include <rtems.h>
57
59
60#ifdef __cplusplus
61extern "C" {
62#endif /* __cplusplus */
63
64#define BSP_ARM_A9MPCORE_SCU_BASE 0x1f000000
65
66#define BSP_ARM_GIC_CPUIF_BASE 0x1f000100
67
68#define BSP_ARM_A9MPCORE_GT_BASE 0x1f000200
69
70#define BSP_ARM_A9MPCORE_PT_BASE 0x1f000600
71
72#define BSP_ARM_GIC_DIST_BASE 0x1f001000
73
74#ifdef __cplusplus
75}
76#endif /* __cplusplus */
77
78#endif /* ASM */
79
80/* @} */
81
82#endif /* LIBBSP_ARM_REALVIEW_PBX_A9_BSP_H */
83
84
This header file provides the default definition of BSP_INITIAL_EXTENSION.
