Global BSP definitions.
More...
#include <bspopts.h>
#include <bsp/lpc32xx.h>
#include <bsp/default-initial-extension.h>
| enum | lpc32xx_nand_controller { LPC32XX_NAND_CONTROLLER_NONE
, LPC32XX_NAND_CONTROLLER_MLC
, LPC32XX_NAND_CONTROLLER_SLC
int | lpc_eth_attach_detach (struct rtems_bsdnet_ifconfig *config, int attaching) |
| | Network driver attach and detach function.
| void * | lpc32xx_idle (uintptr_t ignored) |
| | Optimized idle task.
bool | lpc32xx_start_pll_setup (uint32_t hclkpll_ctrl, uint32_t hclkdiv_ctrl, bool force) |
uint32_t | lpc32xx_sysclk (void) |
uint32_t | lpc32xx_hclkpll_clk (void) |
uint32_t | lpc32xx_periph_clk (void) |
uint32_t | lpc32xx_hclk (void) |
uint32_t | lpc32xx_arm_clk (void) |
uint32_t | lpc32xx_ddram_clk (void) |
void | lpc32xx_select_nand_controller (lpc32xx_nand_controller nand_controller) |
void | bsp_restart (void *addr) |
| void * | bsp_idle_thread (uintptr_t arg) |
