RTEMS 6.1
bsp.h
2
11/*
12 * Copyright (C) 2008, 2014 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_LPC24XX_BSP_H
37#define LIBBSP_ARM_LPC24XX_BSP_H
38
49#include <bspopts.h>
50
51#define BSP_FEATURE_IRQ_EXTENSION
52
53#define LPC24XX_PCLK (LPC24XX_CCLK / LPC24XX_PCLKDIV)
54
55#define LPC24XX_EMCCLK (LPC24XX_CCLK / LPC24XX_EMCCLKDIV)
56
57#define LPC24XX_MPU_REGION_COUNT 8
58
59#define BSP_ARMV7M_IRQ_PRIORITY_DEFAULT (29 << 3)
60
61#define BSP_ARMV7M_SYSTICK_PRIORITY (30 << 3)
62
63#define BSP_ARMV7M_SYSTICK_FREQUENCY LPC24XX_CCLK
64
65#ifndef ASM
66
67#include <rtems.h>
68
70
71#ifdef __cplusplus
72extern "C" {
73#endif /* __cplusplus */
74
75struct rtems_bsdnet_ifconfig;
76
78
83 struct rtems_bsdnet_ifconfig *config,
84 int attaching
85);
86
90#define RTEMS_BSP_NETWORK_DRIVER_ATTACH lpc_eth_attach_detach
91
95#define RTEMS_BSP_NETWORK_DRIVER_NAME "eth0"
96
117void *bsp_idle_thread(uintptr_t ignored);
118
119#ifdef ARM_MULTILIB_ARCH_V4
120 #define BSP_CONSOLE_UART_BASE 0xe000c000
121#else
122 #define BSP_CONSOLE_UART_BASE 0x4000c000
123#endif
124
125void bsp_restart(void *addr);
126
127bool lpc24xx_uart_probe_1(struct rtems_termios_device_context *context);
128
129bool lpc24xx_uart_probe_2(struct rtems_termios_device_context *context);
130
131bool lpc24xx_uart_probe_3(struct rtems_termios_device_context *context);
132
133#ifdef __cplusplus
134}
135#endif /* __cplusplus */
136
137#endif /* ASM */
138
141#endif /* LIBBSP_ARM_LPC24XX_BSP_H */
This header file provides the default definition of BSP_INITIAL_EXTENSION.
void * bsp_idle_thread(uintptr_t ignored)
Optimized idle task.
Definition: bspidle.c:39
int lpc_eth_attach_detach(struct rtems_bsdnet_ifconfig *config, int attaching)
Network driver attach and detach function.
rtems_termios_device_context * context
Definition: console-config.c:62
Definition: deflate.c:114
Termios device context.
Definition: termiosdevice.h:68
