RTEMS 6.1
bsp.h
2
11/*
12 * Copyright (C) 2008, 2013 embedded brains GmbH & Co. KG
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_ARM_LPC176X_BSP_H
37#define LIBBSP_ARM_LPC176X_BSP_H
38
49#include <bspopts.h>
50
51#define LPC176X_PCLK ( LPC176X_CCLK / LPC176X_PCLKDIV )
52#define LPC176X_MPU_REGION_COUNT 8u
53
54#define BSP_FEATURE_IRQ_EXTENSION
55#define BSP_ARMV7M_IRQ_PRIORITY_DEFAULT ( 29u << 3u )
56#define BSP_ARMV7M_SYSTICK_PRIORITY ( 30u << 3u )
57#define BSP_ARMV7M_SYSTICK_FREQUENCY LPC176X_CCLK
58
59#ifndef ASM
60
61#include <rtems.h>
63
64#ifdef __cplusplus
65extern "C" {
66#endif /* __cplusplus */
67
68struct rtems_bsdnet_ifconfig;
69
90void*bsp_idle_thread( uintptr_t ignored );
91
92#define BSP_CONSOLE_UART_BASE 0x4000C000U
93
98void bsp_restart( const void *addr );
99
100#ifdef __cplusplus
101}
102#endif /* __cplusplus */
103
104#endif /* ASM */
105
108#endif /* LIBBSP_ARM_LPC176X_BSP_H */
This header file provides the default definition of BSP_INITIAL_EXTENSION.
void * bsp_idle_thread(uintptr_t ignored)
Optimized idle task.
Definition: bspidle.c:39
