RTEMS 6.1
memory.h
2
3/*
4 * Copyright (C) 2020 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SMEMORYL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef LIBBSP_ARM_IMXRT_IMXRT_MEMORY_H
29#define LIBBSP_ARM_IMXRT_IMXRT_MEMORY_H
30
31#ifdef __cplusplus
32extern "C" {
33#endif
34
35extern char imxrt_memory_null_begin[];
36extern char imxrt_memory_null_end[];
37extern char imxrt_memory_null_size[];
38
39extern char imxrt_memory_itcm_begin[];
40extern char imxrt_memory_itcm_end[];
41extern char imxrt_memory_itcm_size[];
42
43extern char imxrt_memory_dtcm_begin[];
44extern char imxrt_memory_dtcm_end[];
45extern char imxrt_memory_dtcm_size[];
46
47extern char imxrt_memory_ocram_begin[];
48extern char imxrt_memory_ocram_end[];
49extern char imxrt_memory_ocram_size[];
50
51extern char imxrt_memory_ocram_nocache_begin[];
52extern char imxrt_memory_ocram_nocache_end[];
53extern char imxrt_memory_ocram_nocache_size[];
54
55extern char imxrt_memory_peripheral_begin[];
56extern char imxrt_memory_peripheral_end[];
57extern char imxrt_memory_peripheral_size[];
58
59extern char imxrt_memory_flash_raw_begin[];
60extern char imxrt_memory_flash_raw_end[];
61extern char imxrt_memory_flash_raw_size[];
62
63extern char imxrt_memory_flash_config_begin[];
64extern char imxrt_memory_flash_config_end[];
65extern char imxrt_memory_flash_config_size[];
66
67extern char imxrt_memory_flash_ivt_begin[];
68extern char imxrt_memory_flash_ivt_end[];
69extern char imxrt_memory_flash_ivt_size[];
70
71extern char imxrt_memory_flash_begin[];
72extern char imxrt_memory_flash_end[];
73extern char imxrt_memory_flash_size[];
74
75extern char imxrt_memory_extram_begin[];
76extern char imxrt_memory_extram_end[];
77extern char imxrt_memory_extram_size[];
78
79extern char imxrt_memory_extram_nocache_begin[];
80extern char imxrt_memory_extram_nocache_end[];
81extern char imxrt_memory_extram_nocache_size[];
82
83#ifdef __cplusplus
84}
85#endif
86
87#endif /* LIBBSP_ARM_IMXRT_IMXRT_MEMORY_H */
