RTEMS 6.1
irq.h
2
9/*
10 * Copyright (C) 2020 embedded brains GmbH & Co. KG
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef LIBBSP_ARM_IMXRT_IRQ_H
35#define LIBBSP_ARM_IMXRT_IRQ_H
36
37#include <bspopts.h>
38#ifndef ASM
39 #include <rtems/irq.h>
40 #include <rtems/irq-extension.h>
41#endif /* ASM */
42
43#ifdef __cplusplus
44extern "C" {
45#endif /* __cplusplus */
46
47#if IMXRT_IS_MIMXRT10xx
48#define BSP_INTERRUPT_VECTOR_COUNT 160
49#elif IMXRT_IS_MIMXRT11xx
50#define BSP_INTERRUPT_VECTOR_COUNT 217
51#endif
52#define BSP_INTERRUPT_VECTOR_INVALID (UINT32_MAX)
53
54#ifdef __cplusplus
55}
56#endif /* __cplusplus */
57
58#endif /* LIBBSP_ARM_IMXRT_IRQ_H */
This header file is provided for backward compatiblility.
