RTEMS 6.1
bsp.h File Reference
#include <bspopts.h>
#include <bsp/default-initial-extension.h>
#define BSP_FEATURE_IRQ_EXTENSION
#define BSP_FDT_IS_SUPPORTED
#define BSP_ARM_GIC_DIST_BASE   imx_gic_dist_base
#define BSP_ARM_GIC_CPUIF_BASE   (BSP_ARM_GIC_DIST_BASE + 0x1000)
#define BSP_ARM_A9MPCORE_GT_BASE   0
#define BSP_ARM_A9MPCORE_SCU_BASE   0
void * imx_get_reg_of_node (const void *fdt, int node)
rtems_vector_number imx_get_irq_of_node (const void *fdt, int node, size_t index)
void imx_uart_console_drain (void)
int i2c_bus_register_imx (const char *bus_path, const char *alias_or_path)
 Registers an IMX I2C bus driver.
int spi_bus_register_imx (const char *bus_path, const char *alias_or_path)
 Registers an IMX ECSPI bus driver.
uintptr_t imx_gic_dist_base
