RTEMS
6.1
bsps
arm
imx
include
bsp
irq.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* Copyright (c) 2017 embedded brains GmbH & Co. KG
5
6
7
* modification, are permitted provided that the following conditions
8
* are met:
9
* 1. Redistributions of source code must retain the above copyright
10
* notice, this list of conditions and the following disclaimer.
11
* 2. Redistributions in binary form must reproduce the above copyright
12
* notice, this list of conditions and the following disclaimer in the
13
* documentation and/or other materials provided with the distribution.
14
15
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25
* POSSIBILITY OF SUCH DAMAGE.
26
27
28
#ifndef LIBBSP_ARM_IMX_IRQ_H
29
#define LIBBSP_ARM_IMX_IRQ_H
30
31
#ifndef ASM
32
33
rtems/irq.h
34
rtems/irq-extension.h
35
36
dev/irq/arm-gic-irq.h
37
38
#ifdef __cplusplus
39
extern
"C"
40
#endif
/* __cplusplus */
41
42
#define BSP_INTERRUPT_VECTOR_COUNT 160
43
#define BSP_INTERRUPT_VECTOR_INVALID (UINT32_MAX)
44
45
#ifdef __cplusplus
46
47
#endif
/* __cplusplus */
48
49
#endif
/* ASM */
50
51
#endif
/* LIBBSP_ARM_IMX_IRQ_H */
arm-gic-irq.h
This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) support.
irq.h
irq-extension.h
This header file is provided for backward compatiblility.
