RTEMS 6.1
bsp.h
1
7/*
8 * By Yang Xi <hiyangxi@gmail.com>.
9 *
10 * The license and distribution terms for this file may be
11 * found in the file LICENSE in this distribution or at
12 * http://www.rtems.org/license/LICENSE.
13 */
14
15#ifndef LIBBSP_ARM_GUMSTIX_BSP_H
16#define LIBBSP_ARM_GUMSTIX_BSP_H
17
28#include <bspopts.h>
30
31#include <rtems.h>
32
33#ifdef __cplusplus
34extern "C" {
35#endif
36
37#define BSP_FEATURE_IRQ_EXTENSION
38
39#define BSP_HAS_FRAME_BUFFER 1
40
42#define BSP_MAIN_FREQ 3686400 /* 3.6864 MHz */
43#define BSP_SLCK_FREQ 32768 /* 32.768 KHz */
44
46#define BSP_MAX_INT AT91RM9200_MAX_INT
47
48/*
49 * forward reference the type to avoid conflicts between libchip serial
50 * and libchip rtc get and set register types.
51 */
52typedef struct _console_tbl console_tbl;
53console_tbl *BSP_get_uart_from_minor(int minor);
54
55static inline int32_t BSP_get_baud(void) {return 115200;}
56
57#define ST_PIMR_PIV 33 /* 33 ticks of the 32.768Khz clock ~= 1msec */
58
59#define outport_byte(port,val) *((unsigned char volatile*)(port)) = (val)
60#define inport_byte(port,val) (val) = *((unsigned char volatile*)(port))
61#define outport_word(port,val) *((unsigned short volatile*)(port)) = (val)
62#define inport_word(port,val) (val) = *((unsigned short volatile*)(port))
63
64struct rtems_bsdnet_ifconfig;
65extern int rtems_ne_driver_attach(struct rtems_bsdnet_ifconfig *, int);
66#define BSP_NE2000_NETWORK_DRIVER_NAME "ne1"
67#define BSP_NE2000_NETWORK_DRIVER_ATTACH rtems_ne_driver_attach
68
69#ifndef RTEMS_BSP_NETWORK_DRIVER_NAME
70#define RTEMS_BSP_NETWORK_DRIVER_NAME BSP_NE2000_NETWORK_DRIVER_NAME
71#endif
72
73#ifndef RTEMS_BSP_NETWORK_DRIVER_ATTACH
74#define RTEMS_BSP_NETWORK_DRIVER_ATTACH BSP_NE2000_NETWORK_DRIVER_ATTACH
75#endif
76
77#ifdef __cplusplus
78}
79#endif
80
83#endif /* _BSP_H */
84
This header file provides the default definition of BSP_INITIAL_EXTENSION.
Definition: serial.h:136
