RTEMS 6.1
bsp.h
2
3/*
4 * Copyright (C) 2020 embedded brains GmbH & Co. KG
5 *
6 * Redistribution and use in source and binary forms, with or without
7 * modification, are permitted provided that the following conditions
8 * are met:
9 * 1. Redistributions of source code must retain the above copyright
10 * notice, this list of conditions and the following disclaimer.
11 * 2. Redistributions in binary form must reproduce the above copyright
12 * notice, this list of conditions and the following disclaimer in the
13 * documentation and/or other materials provided with the distribution.
14 *
15 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25 * POSSIBILITY OF SUCH DAMAGE.
26 */
27
28#ifndef LIBBSP_ARM_FVP_BSP_H
29#define LIBBSP_ARM_FVP_BSP_H
30
31#include <bspopts.h>
33
34#include <rtems.h>
35
36#ifdef __cplusplus
37extern "C" {
38#endif
39
50#define BSP_FEATURE_IRQ_EXTENSION
51
52extern char arm_fvp_memory_null_begin[];
53extern char arm_fvp_memory_null_end[];
54extern char arm_fvp_memory_null_size[];
55
56extern char arm_fvp_memory_dram_begin[];
57extern char arm_fvp_memory_dram_end[];
58extern char arm_fvp_memory_dram_size[];
59
60extern char arm_fvp_memory_device_begin[];
61extern char arm_fvp_memory_device_end[];
62extern char arm_fvp_memory_device_size[];
63
66#ifdef __cplusplus
67}
68#endif
69
70#endif /* LIBBSP_ARM_FVP_BSP_H */
This header file provides the default definition of BSP_INITIAL_EXTENSION.
