RTEMS 6.1
irq.h
1/*
2 * Interrupt handler Header file
3 *
4 * Copyright (c) 2010 embedded brains GmbH & Co. KG
5 *
6 * Copyright (c) 2004 by Jay Monkman <jtm@lopingdog.com>
7 *
8 * The license and distribution terms for this file may be
9 * found in the file LICENSE in this distribution or at
10 * http://www.rtems.org/license/LICENSE.
11 */
12
13#ifndef __IRQ_H__
14#define __IRQ_H__
15
16#ifndef __asm__
17
18#include <rtems.h>
19#include <rtems/irq.h>
20#include <rtems/irq-extension.h>
21
22#endif /* __asm__ */
23
24/* possible interrupt sources on the MC9328MXL */
25#define BSP_INT_UART3_PFERR 0
26#define BSP_INT_UART3_RTS 1
27#define BSP_INT_UART3_DTR 2
28#define BSP_INT_UART3_UARTC 3
29#define BSP_INT_UART3_TX 4
30#define BSP_INT_PEN_UP 5
31#define BSP_INT_CSI 6
32#define BSP_INT_MMA_MAC 7
33#define BSP_INT_MMA 8
34#define BSP_INT_COMP 9
35#define BSP_INT_MSIRQ 10
36#define BSP_INT_GPIO_PORTA 11
37#define BSP_INT_GPIO_PORTB 12
38#define BSP_INT_GPIO_PORTC 13
39#define BSP_INT_LCDC 14
40#define BSP_INT_SIM_IRQ 15
41#define BSP_INT_SIM_DATA 16
42#define BSP_INT_RTC 17
43#define BSP_INT_RTC_SAM 18
44#define BSP_INT_UART2_PFERR 19
45#define BSP_INT_UART2_RTS 20
46#define BSP_INT_UART2_DTR 21
47#define BSP_INT_UART2_UARTC 22
48#define BSP_INT_UART2_TX 23
49#define BSP_INT_UART2_RX 24
50#define BSP_INT_UART1_PFERR 25
51#define BSP_INT_UART1_RTS 26
52#define BSP_INT_UART1_DTR 27
53#define BSP_INT_UART1_UARTC 28
54#define BSP_INT_UART1_TX 29
55#define BSP_INT_UART1_RX 30
56#define BSP_INT_RES31 31
57#define BSP_INT_RES32 32
58#define BSP_INT_PEN_DATA 33
59#define BSP_INT_PWM 34
60#define BSP_INT_MMC_IRQ 35
61#define BSP_INT_SSI2_TX 36
62#define BSP_INT_SSI2_RX 37
63#define BSP_INT_SSI2_ERR 38
64#define BSP_INT_I2C 39
65#define BSP_INT_SPI2 40
66#define BSP_INT_SPI1 41
67#define BSP_INT_SSI_TX 42
68#define BSP_INT_SSI_TX_ERR 43
69#define BSP_INT_SSI_RX 44
70#define BSP_INT_SSI_RX_ERR 45
71#define BSP_INT_TOUCH 46
72#define BSP_INT_USBD0 47
73#define BSP_INT_USBD1 48
74#define BSP_INT_USBD2 49
75#define BSP_INT_USBD3 50
76#define BSP_INT_USBD4 51
77#define BSP_INT_USBD5 52
78#define BSP_INT_USBD6 53
79#define BSP_INT_UART3_RX 54
80#define BSP_INT_BTSYS 55
81#define BSP_INT_BTTIM 56
82#define BSP_INT_BTWUI 57
83#define BSP_INT_TIMER2 58
84#define BSP_INT_TIMER1 59
85#define BSP_INT_DMA_ERR 60
86#define BSP_INT_DMA 61
87#define BSP_INT_GPIO_PORTD 62
88#define BSP_INT_WDT 63
89#define BSP_MAX_INT 64
90
91#define BSP_INTERRUPT_VECTOR_COUNT BSP_MAX_INT
92
93#endif /* __IRQ_H__ */
This header file is provided for backward compatiblility.
