RTEMS 6.1
spi.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
37#ifndef _SPI_
38#define _SPI_
39
40/*----------------------------------------------------------------------------
41 * Headers
42 *----------------------------------------------------------------------------*/
43
44#include "chip.h"
45
46/*----------------------------------------------------------------------------
47 * Macros
48 *----------------------------------------------------------------------------*/
49
63#define SPI_PCS(npcs) SPI_MR_PCS((~(1 << npcs) & 0xF))
64
66#define SPI_SCBR(baudrate, masterClock) \
67 SPI_CSR_SCBR((uint32_t)(masterClock / baudrate))
68
70#define SPI_DLYBS(delay, masterClock) \
71 SPI_CSR_DLYBS((uint32_t) (((masterClock / 1000000) * delay) / 1000)+1)
72
74#define SPI_DLYBCT(delay, masterClock) \
75 SPI_CSR_DLYBCT ((uint32_t) (((masterClock / 1000000) * delay) / 32000)+1)
76
77/*------------------------------------------------------------------------------ */
78
79#ifdef __cplusplus
80extern "C" {
81#endif
82
83/*----------------------------------------------------------------------------
84 * Exported functions
85 *----------------------------------------------------------------------------*/
86
87extern void SPI_Enable(Spi *spi);
88extern void SPI_Disable(Spi *spi);
89
90extern void SPI_EnableIt(Spi *spi, uint32_t dwSources);
91extern void SPI_DisableIt(Spi *spi, uint32_t dwSources);
92
93extern void SPI_Configure(Spi *spi, uint32_t dwId, uint32_t dwConfiguration);
94extern void SPI_SetMode(Spi *spi, uint32_t dwConfiguration);
95
96extern void SPI_ChipSelect(Spi *spi, uint8_t cS);
97extern void SPI_ReleaseCS(Spi *spi);
98
99extern void SPI_ConfigureNPCS(Spi *spi, uint32_t dwNpcs,
100 uint32_t dwConfiguration);
101extern void SPI_ConfigureCSMode(Spi *spi, uint32_t dwNpcs,
102 uint32_t bReleaseOnLast);
103
104extern uint32_t SPI_Read(Spi *spi);
105extern void SPI_Write(Spi *spi, uint32_t dwNpcs, uint16_t wData);
106extern void SPI_WriteLast(Spi *spi, uint32_t dwNpcs, uint16_t wData);
107
108extern uint32_t SPI_GetStatus(Spi *spi);
109extern uint32_t SPI_IsFinished(Spi *pSpi);
110
111#ifdef __cplusplus
112}
113#endif
114
115#endif /* #ifndef _SPI_ */
116
Configures a SPI peripheral as specified. The configuration can be computed using several macros (see...
Definition: spi.c:128
Reads and returns the last word of data received by a SPI peripheral. This method must be called afte...
Definition: spi.c:225
void SPI_ConfigureNPCS(Spi *spi, uint32_t dwNpcs, uint32_t dwConfiguration)
Configures a chip select of a SPI peripheral. The chip select configuration is computed using several...
Definition: spi.c:184
Configures SPI chip select.
Definition: spi.c:146
Sends data through a SPI peripheral. If the SPI is configured to use a fixed peripheral select,...
Definition: spi.c:241
Check if SPI transfer finish.
Definition: spi.c:278
Enables one or more interrupt sources of a SPI peripheral.
Definition: spi.c:104
Get the current status register of the given SPI peripheral.
Definition: spi.c:212
Sends last data through a SPI peripheral. If the SPI is configured to use a fixed peripheral select,...
Definition: spi.c:260
Disables a SPI peripheral.
Definition: spi.c:93
void SPI_ConfigureCSMode(Spi *spi, uint32_t dwNpcs, uint32_t bReleaseOnLast)
Configures a chip select active mode of a SPI peripheral.
Definition: spi.c:197
Configures SPI Mode Register.
Definition: spi.c:158
Enables a SPI peripheral.
Definition: spi.c:83
Disables one or more interrupt sources of a SPI peripheral.
Definition: spi.c:115
Configures SPI to release last used CS line.
Definition: spi.c:169
Spi hardware registers.
Definition: component_spi.h:41
