RTEMS 6.1
bsp.h
2
9/*
10 * Copyright (c) 2016 embedded brains GmbH & Co. KG
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef LIBBSP_ARM_ATSAM_BSP_H
35#define LIBBSP_ARM_ATSAM_BSP_H
36
47#include <bspopts.h>
49#include <sys/ioccom.h>
50
51#include <rtems.h>
52
53#ifdef __cplusplus
54extern "C" {
55#endif /* __cplusplus */
56
57#define BSP_FEATURE_IRQ_EXTENSION
58
59#define BSP_ARMV7M_IRQ_PRIORITY_DEFAULT (13 << 4)
60
61#define BSP_ARMV7M_SYSTICK_PRIORITY (14 << 4)
62
63uint32_t atsam_systick_frequency(void);
64
65#define BSP_ARMV7M_SYSTICK_FREQUENCY atsam_systick_frequency()
66
67struct rtems_bsdnet_ifconfig;
68
69int if_atsam_attach(struct rtems_bsdnet_ifconfig *config, int attaching);
70
71#define RTEMS_BSP_NETWORK_DRIVER_NAME "atsam0"
72
73#define RTEMS_BSP_NETWORK_DRIVER_ATTACH if_atsam_attach
74
78typedef struct {
82 uint32_t mdio_retries;
83
89 uint8_t phy_addr;
91
92extern char atsam_memory_null_begin[];
93extern char atsam_memory_null_end[];
94extern char atsam_memory_null_size[];
95
96extern char atsam_memory_dtcm_begin[];
97extern char atsam_memory_dtcm_end[];
98extern char atsam_memory_dtcm_size[];
99
100extern char atsam_memory_intflash_begin[];
101extern char atsam_memory_intflash_end[];
102extern char atsam_memory_intflash_size[];
103
104extern char atsam_memory_intsram_begin[];
105extern char atsam_memory_intsram_end[];
106extern char atsam_memory_intsram_size[];
107
108extern char atsam_memory_itcm_begin[];
109extern char atsam_memory_itcm_end[];
110extern char atsam_memory_itcm_size[];
111
112extern char atsam_memory_nocache_begin[];
113extern char atsam_memory_nocache_end[];
114extern char atsam_memory_nocache_size[];
115
116extern char atsam_memory_qspiflash_begin[];
117extern char atsam_memory_qspiflash_end[];
118extern char atsam_memory_qspiflash_size[];
119
120extern char atsam_memory_sdram_begin[];
121extern char atsam_memory_sdram_end[];
122extern char atsam_memory_sdram_size[];
123
124void atsam_rtc_get_time(rtems_time_of_day *tod);
125
126
127
128void bsp_restart( const void *const addr );
129
130/*
131 * This ioctl enables the receive DMA for an UART. The DMA can be usefull if you
132 * loose characters in high interrupt load situations.
133 *
134 * Disabling the DMA again is only possible by closing all file descriptors of
135 * that UART.
136 *
137 * Note that every UART needs one DMA channel and the system has only a limited
138 * amount of DMAs. So only use it if you need it.
139 */
140#define ATSAM_UART_ENABLE_RX_DMA _IO('d', 0)
141
142#ifdef __cplusplus
143}
144#endif /* __cplusplus */
145
148#endif /* LIBBSP_ARM_ATSAM_BSP_H */
This header file provides the default definition of BSP_INITIAL_EXTENSION.
Definition: deflate.c:114
Interface driver configuration.
Definition: bsp.h:78
uint8_t phy_addr
Address of PHY.
Definition: bsp.h:89
Maximum retries for MDIO communication.
Definition: bsp.h:82
This type represents Classic API calendar times.
Definition: types.h:266
