RTEMS 6.1
irq.h
2
9/*
10 * Copyright (c) 2013 embedded brains GmbH & Co. KG
11 *
12 * Redistribution and use in source and binary forms, with or without
13 * modification, are permitted provided that the following conditions
14 * are met:
15 * 1. Redistributions of source code must retain the above copyright
16 * notice, this list of conditions and the following disclaimer.
17 * 2. Redistributions in binary form must reproduce the above copyright
18 * notice, this list of conditions and the following disclaimer in the
19 * documentation and/or other materials provided with the distribution.
20 *
21 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31 * POSSIBILITY OF SUCH DAMAGE.
32 */
33
34#ifndef LIBBSP_ARM_ALTERA_CYCLONE_V_IRQ_H
35#define LIBBSP_ARM_ALTERA_CYCLONE_V_IRQ_H
36
37#ifndef ASM
38
39#include <rtems/irq.h>
40#include <rtems/irq-extension.h>
41
43#include <dev/irq/arm-gic-irq.h>
45
46#ifdef __cplusplus
47extern "C" {
48#endif /* __cplusplus */
49
62/* Use interrupt IDs as defined in alt_interrupt_common.h */
63#define BSP_INTERRUPT_VECTOR_COUNT \
64 (ALT_INT_INTERRUPT_RAM_ECC_UNCORRECTED_IRQ + 1)
65
68#ifdef __cplusplus
69}
70#endif /* __cplusplus */
71
72#endif /* ASM */
73
74#endif /* LIBBSP_ARM_ALTERA_CYCLONE_V_IRQ_H */
This header file provides the interfaces of the Cortex-A9 MPCore Support.
This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) support.
This header file is provided for backward compatiblility.
