RTEMS 6.1
irq.h
2
11/*
12 * Copyright (C) 2020 On-Line Applications Research Corporation (OAR)
13 * Written by Kinsey Moore <kinsey.moore@oarcorp.com>
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef LIBBSP_AARCH64_XILINX_ZYNQMP_IRQ_H
38#define LIBBSP_AARCH64_XILINX_ZYNQMP_IRQ_H
39
40#ifndef ASM
41
42#include <rtems.h>
43
44#include <dev/irq/arm-gic-irq.h>
45
46#ifdef __cplusplus
47extern "C" {
48#endif /* __cplusplus */
49
50#define BSP_INTERRUPT_VECTOR_COUNT 192
51
52/* Interrupts vectors */
53#define BSP_TIMER_VIRT_PPI 27
54#define BSP_TIMER_PHYS_NS_PPI 30
55#define ZYNQMP_IRQ_OCM 42
56#define ZYNQMP_IRQ_QSPI 47
57#define ZYNQMP_IRQ_I2C_0 49
58#define ZYNQMP_IRQ_I2C_1 50
59#define ZYNQMP_IRQ_UART_0 53
60#define ZYNQMP_IRQ_UART_1 54
61#define ZYNQMP_IRQ_ETHERNET_0 89
62#define ZYNQMP_IRQ_ETHERNET_1 91
63#define ZYNQMP_IRQ_ETHERNET_2 93
64#define ZYNQMP_IRQ_ETHERNET_3 95
65#define ZYNQMP_IRQ_DDR 144
66#define ZYNQMP_IRQ_CACHE 183
67
70#ifdef __cplusplus
71}
72#endif /* __cplusplus */
73
74#endif /* ASM */
75
76#endif /* LIBBSP_AARCH64_XILINX_ZYNQMP_IRQ_H */
This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) support.
