RTEMS 6.1
bsp.h
2
11/*
12 * Copyright (C) 2021 Gedare Bloom <gedare@rtems.org>
13 *
16 * are met:
22 *
34 */
35
36#ifndef LIBBSP_AARCH64_XILINX_VERSAL_BSP_H
37#define LIBBSP_AARCH64_XILINX_VERSAL_BSP_H
38
45#include <bspopts.h>
46
47#define BSP_RESET_SMC
48
49#ifndef ASM
50
52#include <bsp/linker-symbols.h>
53#include <bsp/start.h>
54
55#include <rtems.h>
56
57#ifdef __cplusplus
58extern "C" {
59#endif /* __cplusplus */
60
61#define BSP_ARM_GIC_CPUIF_BASE 0xf9040000
62#define BSP_ARM_GIC_DIST_BASE 0xf9000000
63#define BSP_ARM_GIC_REDIST_BASE 0xf9080000
64
65/*
66 * DDRMC mapping
67 */
68LINKER_SYMBOL(bsp_r0_ram_base)
69LINKER_SYMBOL(bsp_r0_ram_end)
70LINKER_SYMBOL(bsp_r1_ram_base)
71LINKER_SYMBOL(bsp_r1_ram_end)
72
73
78BSP_START_TEXT_SECTION void versal_setup_mmu_and_cache(void);
79
80void versal_debug_console_flush(void);
81
82uint32_t versal_clock_i2c0(void);
83
84uint32_t versal_clock_i2c1(void);
85
86#ifdef __cplusplus
87}
88#endif /* __cplusplus */
89
90#endif /* ASM */
91
94#endif /* LIBBSP_AARCH64_XILINX_VERSAL_BSP_H */
This header file provides the default definition of BSP_INITIAL_EXTENSION.
Versal specific set up of the MMU.
Definition: bspstartmmu.c:97
This header file provides interfaces to BSP-specific linker symbols and sections.
