RTEMS 6.1
bsp.h
2
11/*
12 * Copyright (C) 2022 Mohd Noor Aman
13 *
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37#ifndef LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H
38#define LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H
39
46#include <bspopts.h>
47
48#ifndef ASM
49
51#include <bsp/start.h>
52
53#include <rtems.h>
54
55/*Raspberry pi MMU initialization */
56BSP_START_TEXT_SECTION void raspberrypi_4_setup_mmu_and_cache(void);
57
58#ifdef __cplusplus
59extern "C" {
60#endif /* __cplusplus */
61
62#define BSP_ARM_GIC_CPUIF_BASE 0xFF842000
63#define BSP_ARM_GIC_DIST_BASE 0xFF841000
64
65#ifdef __cplusplus
66}
67#endif /* __cplusplus */
68
69#endif /* ASM */
70
73#endif /* LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H */
This header file provides the default definition of BSP_INITIAL_EXTENSION.
